can someone please tell me how I’m supposed to prevent Audirvana from having a major RAM memory leak on macOS … it always eventually freezes my computer unless i force close the app every 2 days or less
Latest Audirvana installed (not the subscription version) … I paid a lot for this app, but it’s looking like I have to find another app because this has been a problem for a long time and it looks like they are not updating it
I don’t know what MacOS you use, but there seems to be a problem with major memory leaks in Monterey. If you are using Monterey it can be a problem with the OS instead of Audirvana.
In Linux you can follow each bit of data as it enters the OS and specifically define how you want the processor[s], memory etc to handle them…all the way down to the processor cycles. I specify exactly which processor core handles my audio data, exactly how much memory is dedicated to audio and exactly which processor[s] handles the digital audio output. Fine tuning to the max!
Basically I create a HOV lane in my OS to handle audio-data from entry to exit.
