Have been getting to know Audirvana (3.5.41, on 10.14.6) for a week or two now. Love it!
Still not sure how Grouping works: ideally I’d like to be able to collapse all four tracks, say, of a four movement symphony - so that only the title of the work appears.
Have tried putting a string into the Grouping metadata field such as ‘Symphony number 4 in C minor’; that doesn’t seem to work.
What am I doing wrong, please?
I also searched far and wide for a Mac version 3.5 manual. Does such a document exist, please?
(This is the closest I could find, but seems to differ significantly from version 3.)
You could use the filter functionality.
An example:
select your composer, you’ll have all the albums of that composer
then open the filter section and select Grouping as filtering criteria.
You’ll then be able to select the Composition/Grouping you want
The Composition/Grouping will be shown for any album in which it appears
… unfortunately Grouping collapsing is not available
