Is there a way to re-order playlists independent of any meta data? I understand from other threads there is a “manual order” option but that seems to only give additional sort options based on meta-data within the file. I am asking if there is a way to re-order based on personal preference…such as “this song sounds good after this one…” and so on, but not based on any metadata/id3 info.
Hello @kirkball, yes you can do that. In fact you need to have the option “sort manual playlist” do do this
Thank you! I had thought I had it checked when in fact it was unchecked.
