Hey lately im having to use Vox instead of audirvana which I pay yearly for due to the many issues im having with the program.
when I go to add a new folder in audirvana local I get an error message : Fatal Error adding folder to watch list. Unexpected error while adding folder /Volumes/… Library to the watch list
when I try to delete a folder from local it does nothing at all.
the rating system does not work and has barely worked properly since I started using audirvana. the 5 star rating thing doesn’t change at all when u click on the stars nothing happens and if it does change its never permanent.
same issue with the heart/love rating system. if it ever clicks properly its never permanent and rarely makes loved albums or tracks stay in the loved/heart playlists.
there was a good way of searching using folder and that has been removed I think, making it difficult at times to search when u have a large local library. (But this issue isn’t as important.)
!! EDITED*
6. When I use the “check database integrity” or “rebuild indexes” options, I get a long list that I cannot scroll down to press ok at the bottom, I end up having to restart the app.
I have tried updating my Mac and audirvana. I have tried uninstalling and reinstalling.
DEBUG INFO:
Audirvana Studio 1.14.0 (11400)
macOS 11.6.7 with 8GB physical RAM
Connected account of :
Replay Gain: by album
Sync list: 2 folders
Manual: (OFFLINE) /Volumes/HGST 1TB /2. More Music
AUTO: /Volumes/Transcend/Sorted Music*
Library database path: /Users/home/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 65130
Max. memory for audio buffers: 1106MB
Exclusive access: Disabled
FFFF EDIFIER R1700BT
Model UID:ffff 0
UID:5c-c6-e9-86-bb-3b:output
ID 0x32 Built-in Output
Model Name: Apple Inc. Built-in Output
Model UID: AppleHDA:93
Stream ID 0x33 2 channels starting at 1
4 virtual formats:
12 physical formats
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
