first of all, my english is terrible. Excuse
I use a notebook AMD ryzen 7 (new generation) and marantz hd-dac1.
I bought origin today.
In every configuration (wasapi, asio or kernel) my system goes crash when i try to open a dsd file, without system error,
the driver asio is detect.
I already downloaded a driver for my dac.
Someone can help me?
I have an HD-DAC1, works fine on macOS.
But I can try Windows, what Windows version are you using?
windows 11 pro
Hello. welcome…
More information is needed so folks can best help…
Please post (copy and paste) your debug information here… found in ‘Settings’ → ‘Help’ – ‘Debug Info’.
Audirvana Origin 2.5.6 (20506)
Windows 11 (22621) with 16GB physical RAM
Connected account of : Nunzio Recano
Available network interfaces:
WIFI_ISS_363995uno ({83bf9168-be27-4934-8f37-d63d5917264d}) is PUBLIC
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Sync list: 2 folders
AUTO: \musica\musica\classica hi res
AUTO: \musica\musica\classica low res
Library database path: C:\Users\nunzi\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on fd1e:74c0:6771:4d39:c5d0:3826:a121:1fba on port 61235
Max. memory for audio buffers: 8192MB
Local Audio Engine: ASIO 2
Driver version 1
Marantz ASIO Device
Model UID:Marantz ASIO Device
Active Sample Rate: 96kHz
Limit bitdepth to 24bit: ON
Selected device:Marantz ASIO Device
Manufacturer:
Model name: Marantz ASIO Device
Model UID: Marantz ASIO Device
9 available sample rates up to 5644800Hz
5644800
DSD capability: Raw DSD (msb)
Device #0: Marantz ASIO Device
Manufacturer:
UPnP devices found : 2
Device #0: LEMEGA M3+ 00226143f4f0
UID: uuid:3DCC7100-F76C-11DD-87AF-00226143F4F0
Manufacturer: Frontier Silicon Ltd
Model name:
Device #1: MacBook-Air-di-nunzio-2.local
UID: uuid:27b33e98-e45b-c244-9fb0-7a7f374bdc36
Location: http://192.168.5.42:52101/DeviceDescription.xml
Manufacturer: JRiver, Inc.
Model name: Media Center
audirvana goes idle and doesnt respond. I have to close brutally and restart the app
Can you send us your audirvana_origin.log file at support@audirvana.com?
to show AppData folder:
do it
merry christmas!!
by the way my problem is always on
