Damien, it does change, but not āat the same timeā. There is a lot of delay and sometimes it doesnāt change at all.
Can you send me a copy of the āDebug Infoā? You can get it in Audirvana Settings>General>Debug Info
Here you go:
macOS 11.1.0 with 32768MB RAM
Registriert nach Christoph BƤurle
Phase = 100
SW volume control: ON
AUTO: /Volumes/Media/HD Musik
Library database path: /Users/christophbaeurle/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3276MB
Exclusive access: Disabled
Sonarworks Systemwide
Model UID:com_sonarworks_driver_SonarworksDevice:Sonarworks
UID:SonarworksEngine:0
Active Sample Rate: 96kHz
Sample rate limitation: 96kHz
Sample rate switching latency: 1s
ID 0x66 Sonarworks Systemwide Manufacturer:SIA Sonarworks
Model UID:com_sonarworks_driver_SonarworksDevice:Sonarworks UID:SonarworksEngine:0
Stream ID 0x67 2 channels starting at 1
6 virtual formats:
6 physical formats
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 192kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 176.4kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 96kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 88.2kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 48kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 44.1kHz
Local devices found : 5
Device #0: ID 0x52 Acer ET430K Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{7204-0558-7320595B}
Device #1: ID 0x56 MC-3+ Smart Clock USB 2.0 Manufacturer: MUTEC GmbH Model UID: MC-3+ Smart Clock USB 2.0:29A2:0086 UID: AppleUSBAudioEngine:MUTEC GmbH:MC-3+ Smart Clock USB 2.0:14641000:1,2
Device #2: ID 0x48 Mac mini Lautsprecher Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #3: ID 0x66 Sonarworks Systemwide Manufacturer: SIA Sonarworks Model UID: com_sonarworks_driver_SonarworksDevice:Sonarworks UID: SonarworksEngine:0
Device #4: ID 0x4e Universal Audio Thunderbolt Manufacturer: Universal Audio, Inc. Model UID: com_uaudio_driver_UAD2System:Universal Audio Apollo UID: com_uaudio_driver_UAD2AudioEngine:0
chris23086 I am having the same problem where the volume slider in the app automatically returns to the center position. I have to slide it to the left as quickly as possible in order to avoid a massive volume surge. Audirvana support has asked me all the same questions that they are asking you now but it does not address the problem. Something in the app is causing the slider issue. They need to update the app and improve the volume control functionality at the same time.
Hello @chris23086, do you have the issue whatever the output you use?
Hi all, I have a similar issue when I configure a specific āmax volumeā value different from 100.
In this case, sometime, the volume automatically shift to a high value with no reasons. This may be very dangerous as I intend to use my 3dlab streamer as a preamp also, directly connected to a poweramp.
This issue does not existe when the max volume is set to 100.
Anyone with the same issue ? Any workaround ?
Thanks for your help
