Audio Signal Analysis (Audirvana 2.2.3 / MacOS 13.2 ) Memory Leak
Anyone else came across this issue ?
Running Audirvana Studio 2.2.3 MacBook Pro M1 16gb, Ventura 13.2, Memory usage never breaks 870mb. Audio scan barely causes a blip in memory usage. Further testing to emulate Orgin, local files vs QOBUZ. Local files playback and audio scan increased memory usage to 1.02 gb
Please post your debug and perhaps the forum will see something useful to help you improve it.
First post! Welcome aboard the ship @pmik
here is debug info:
Audirvana Origin 2.2.3 (20203)
macOS Version 13.2 (Build 22D49) with 16GB physical RAM
Connected account of : Przemek Mik
AUTO: /Volumes/T7 Touch/Music/High Quality Music
Library database path: /Users/pmik/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 58165
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Apple Inc. Beosound A1 2nd Gen
Model UID:102e 103
UID:B8-D5-0B-F8-F9-37:output
Selected device:Beosound A1 2nd Gen
Model name: Apple Inc. Beosound A1 2nd Gen
Model UID: 102e 103
UID: B8-D5-0B-F9-A7-40:output
ID 0x81
2 available sample rates up to 44100Hz
16000
Audio buffer frame size : 14 to 1024 frames
Stream ID 0x82 2 channels starting at 1
2 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 16kHz
2 physical formats
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 16kHz
Local devices found : 7
Device #0: ID 0x3d LG HDR 4K
Manufacturer: GSM
Model UID: 1E6D5077-0000-0000-071F-0104B5462878
Model name: GSM LG HDR 4K
Device #1: ID 0x36 BTD 600
Manufacturer: BTD 600
Model UID: BTD 600:3542:3000
UID: AppleUSBAudioEngine:BTD 600:BTD 600:011E082C003291AB3C08:4
USB Vendor ID: 0x3542
USB Product ID: 0x3000
Model name: BTD 600
Device #2: ID 0x81 Beosound A1 2nd Gen
Model UID: 102e 103
Device #3: ID 0x73 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #4: ID 0x4c MMAudio Device
Manufacturer: MMAudio Device contributors
Model UID: MMAudioDeviceModelUID
UID: MMAudioDevice
Model name: MMAudio Device contributors MMAudio Device
Device #5: ID 0x52 MMAudio Device (UI Sounds)
Model UID: MMAudioDeviceModelUID_UISounds
UID: MMAudioDevice_UISounds
Model name: MMAudio Device contributors MMAudio Device (UI Sounds)
Device #6: ID 0x56 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
UPnP devices found : 1
Device #0: ID 0x0 : [TV] Samsung Q80 Series (65)
UID: uuid:5d591865-8d0e-4f67-98d8-0a83cbc0e53b
Manufacturer: Samsung Electronics
Model name: QE65Q85RATXZG
Chromecast devices found : 1
Device #0: Bedroom Smart Clock
Model name: Lenovo Smart Clock
noticed that this happens only on analysis of one Flac fileā¦
First thing that jumps out is this, you donāt need this large of a buffer. Reduce to 4000/6000mb and see how playback goes.
How large is the file?
The file is 220 Mb.
You should email that file to @Antoine at [email protected] so that they can see whatās up with it.
Yes, the file was faulty, removed it, all good.
