Meridian Explorer 2 does not play DSD64 files
Hi! I have some issues with the Meridian Explorer 2 DAC. Firstly, the DAC info in Audirvana says that the Explorer supports DSD64. This is not correct. Secondly, when trying to play a DSD64 file, I only hear a hiss. DSD128 play fine, though. I have the latest version of Audirvana on a MacBook Pro Big Sur using USB-C connection to the DAC. / Jan Gustafsson
Hello @jan_gustafsson,
That’s detection error. The Explorer2 does not support DSD at all. The reason why you can play DSD128 is because it’s automatically converted to PCM.
In the Native DSD streaming method, just select “none: convert to PCM”. You need to stop the playback (by clicking on the square STOP button) to be able to change that.
macOS 11.2.0 with 16384MB RAM
Registered to Jan Gustafsson
Replay Gain: by track
SW volume control: ON
AUTO: /Users/jgn01 1/Music
iTunes/Music library synchronization: last synchronized on Fri Feb 5 05:12:04 2021
Library database path: /Users/jgn01 1/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Explorer² USB DAC
Model UID:Explorer² USB DAC:1CBA:0031
UID:AppleUSBAudioEngine:Meridian:Explorer² USB DAC:01312ECC:1
Active Sample Rate: 48kHz
ID 0x89 Explorer² USB DAC Manufacturer:Meridian
Model UID:Explorer² USB DAC:1CBA:0031 UID:AppleUSBAudioEngine:Meridian:Explorer² USB DAC:01312ECC:1
MQA Decoder device
Stream ID 0x8a 2 channels starting at 1
18 virtual formats:
24 physical formats
Local devices found : 7
Device #0: ID 0x89 Explorer² USB DAC Manufacturer: Meridian Model UID: Explorer² USB DAC:1CBA:0031 UID: AppleUSBAudioEngine:Meridian:Explorer² USB DAC:01312ECC:1
Device #1: ID 0x45 BlackHole 2ch Manufacturer: Existential Audio Inc. Model UID: BlackHole2ch_ModelUID UID: BlackHole2ch_UID
Device #2: ID 0x3c BlackHole 16ch Manufacturer: Existential Audio Inc. Model UID: BlackHole_ModelUID UID: BlackHole_UID
Device #3: ID 0x7d Högtalare i MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #4: ID 0x56 ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001
Device #5: ID 0x34 QuickTime Player input Manufacturer: Apple Inc. Model UID: ~:AMS2_Aggregate:0 UID: ~:AMS2_Aggregate:0
Device #6: ID 0x38 Screen record w audio Manufacturer: Apple Inc. Model UID: ~:AMS2_StackedOutput:0 UID: ~:AMS2_StackedOutput:0
