Metadata handling explanation
Is there a good explanation of how Origin handles metadata? I’m currently ripping a moderately large CD collection via Apple Music/iTunes to a library stored on a NAS. I have Origin pointed at the library folder on the NAS.
It updates as new material is added, but doesn’t always show album artwork. It also seems to ‘enhance’ the metadata compared with what’s shown in Apple Music (e.g. shows composer dates, production year). Not sure if that’s because the data is already there in the iTunes library, but not displayed in Apple Music, or if it’s because Origin does some additional look ups somewhere.
Either way, an overview of how Origin handles metadata would be very helpful. (As would any tips for improving the process I described above.)
Thanks!
Hi @stephent,
In the case of metadata, we read everything that is embedded inside the file itself. But in the case of album artwork, iTunes tends to not add them inside the tracks. You can see this if you use a different metadata editor like Musicbrainz.
To fix this, you can manually add the album artwork inside the folder of the album concerned and Audirvāna Origin will see it for all the tracks in it.
Thanks @Antoine. I’ll try to learn more about metadata editing and embedding - seems that’s a whole world unto itself. I’m familiar with how it works with image files, but not so much for audio.
One follow-up question: should it be possible to drag and drop artwork onto an Album in Origin? I had it working for 3 or 4 albums, but now every time I try it, the app hangs indefinitely.
Can you please send a screenshot when you do the drag & drop in the app?
@Antoine Here’s a link to a screen capture video: it doesn’t show the mouse cursor change to SBOD after I drop the artwork. I have to force quit and restart to recover (on reboot, the new artwork is not there).
Debug info:
Audirvana Origin 2.5.9 (20509)
macOS 13.5.1 with 32GB physical RAM
Connected account of : Stephen Trainor
	r8brain with 2x upsampling
	Sync list: 2 folders
		AUTO: /Volumes/music-1/iTunes
		AUTO: /Volumes/music/dBpoweramp
	Library database path: /Users/stephen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
	Deep Synch: yes
	Intializing
	Listening on 127.0.0.1 on port 56756
Local Audio Engine: CoreAudio
	Exclusive access: ON
	Integer mode: ON
	CA CA DacMagic 200M 2.0
	Model UID:CA DacMagic 200M 2.0:22E8:DAC2
	UID:AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:5300000:1
Active Sample Rate: 96kHz
Selected device:MacBook Pro Speakers
	Model UID: Speaker
	UID: BuiltInSpeakerDevice
	ID 0x45
Stream ID 0x46 2 channels starting at 1
4 virtual formats:
4 physical formats
Local devices found : 4
	Device #0: ID 0x71 Studio Display Speakers
		Model UID: Studio Display Audio Control:05AC:1114
		UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001A254826F0802E:8,9
		USB Vendor ID: 0x05ac
		USB Product ID: 0x1114
		Model name: Apple Inc. Studio Display Speakers
	Device #1: ID 0x5c CalDigit Thunderbolt 3 Audio
		Manufacturer: CalDigit, Inc.
		Model UID: CalDigit Thunderbolt 3 Audio:2188:6533
		UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:3200000:1
		USB Vendor ID: 0x2188
		USB Product ID: 0x6533
		Model name: CalDigit, Inc. CalDigit Thunderbolt 3 Audio
	Device #2: ID 0x45 MacBook Pro Speakers
		Model UID: Speaker
	Device #3: ID 0x52 Microsoft Teams Audio
		Manufacturer: Microsoft Corp.
UPnP devices found : 1
	Device #0: ID 0x0 : Mu-so Qb 0539
		UID: uuid:3165e780-d78d-49d6-a524-ad9fac5bb3f8
		Location: http://192.168.1.203:46442/3165e780-d78d-49d6-a524-ad9fac5bb3f8.xml
		Manufacturer: Naim Audio
		Model name: Mu-so Qb
Chromecast devices found : 1
	Device #0: Mu-so Qb 0539
Hi @stephent, I can’t see your video, can you send it at [email protected]?
