~ I like to keep my metadata as clean and consistent as possible. When I see that in Audirvana there is a song, album, or artist incorrectly displaying in my Library, I use Tag Edit (software) to find the problem and correct the data.
~ When I restart Audirvana and wait for it to sync, the problem remains. Audirvana does not update the metadata correction I have made and I continue to see the problem in the Library display.
~ To be sure that I made the change properly, I have navigated to User>Librrary>Application Support>Audirvana and deleted the “AudirvanaPlusDatabaseV2.sqlite” file.
~ When I restart Audirvana, point it to my music file folder, wait for it to Sync (rebuild the database), the changes to the metadata I made have been updated and display properly on my Audirvana, library window.
It appears that Audirvana’s syncing with the Monitored folder is not working.
Question: Am I doing something wrong or is this a well known issue. I see one post here titled: "Any updates on metadata handling? which touches on this issue, but not completely.
