UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192 - 354 - 384
DSD supported sample rate : 64 - 128 - 256
DSD Over PCM setting : None
MQA capability : Renderer
Volume:
Volume can be changed : No
Device can mute - unmute: No
Playback:
Setting do not send RAW PCM activated : No
Playback Control:
Gapless playbak option enabled : No
USB:
Detection:
(Windows only) best option to play to the device : ASIO
DSD Over PCM setting : DoP 1.0
