I did not know this one. Was bad enough not being able to play songs till the end and move to the next track, having two pops in middle of songs and switching to next one, Audirvana is creating Mini Dumps now! Every time it stops a few seconds before the end of a song and I try to move to the next one, another small window shows up with mini dump to be stored in Explorer or not then AV shuts down. 2 different debugs below.
Audirvana 3.5.45
SoX to DSD512 with filter type B 8th order
Bandwidth at 0dB = 90.007
Phase = 0
Manual: (OFFLINE) E:\backup-003836
Library database path: C:\Users\jeanf\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4088MB
Local Audio Engine:ASIO 2 driver version 2
T+A PDP3000 USB ASIO
Model UID:T+A PDP3000 USB ASIO
Active Sample Rate: 2822.4kHz
T+A PDP3000 USB ASIO Manufacturer:
Model UID:T+A PDP3000 USB ASIO UID:T+A PDP3000 USB ASIO
13 available sample rates up to 45158400Hz
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: T+A PDP3000 USB ASIO Manufacturer: Model UID: T+A PDP3000 USB ASIO UID: T+A PDP3000 USB ASIO
Device #1: TEAC ASIO USB DRIVER Manufacturer: Model UID: TEAC ASIO USB DRIVER UID: TEAC ASIO USB DRIVER
Hours later.
Audirvana 3.5.45
Phase = 0
Device: 2ch 8bits Integer, 2 bytes per frame 22579.2kHz
Active Sample Rate: 22579.2kHz
5644800
11289600
22579200
45158400
