While the main display shows preloading and replay OK the Mini player display does not.
Preloading (grey) stops before it’s finished - replay (blue/purple) then advances behind the cursor to the point where the preloading bar ends. The white cursor then launches off without either the replay or preload ribbons - see attached screen shot.
