Missing release dates + other problems with library
Hi @dZp,
Thank you for sharing your knowledge!
Since I am filling the releasetime tag for some time now, I have added the first trigger you described to my database. This works perfectly and it gives me better control over the information that is imported into Audirvana as the second trigger described by you.
Just for reference, I have Audirvana running on Windows and I use MP3Tag for tagging the audio files. I do not edit the metadata directly in Audirvana.
Thanks again!
Best regards
Christian
Hi Antoine,
Any news on the pre 1970 date tag issue? Cheers
hi @kristeva , using the beta of Audirvāna Studio, the issue should be fixed. It will be brought to Audirvāna Origin later this year.
Hi Antoine,
That’s great news, thanks.
