Missing thumbnails TIDAL ARTIST
how to fix missing thumbnails?
Audirvana Studio 2.11.1 (21101)
Windows 11 (26100) x86_64 with 32GB physical RAM
Connected account of : xxx
Available network interfaces:
Ethernet (xxx) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
LOADING/DECODING:
Max audio buffer size: 10840MB
Internal EQ: OFF
Effect Plugins: NOT ACTIVE
Sync list: 2 folders
AUTO: D:\Muzyka
AUTO: D:\Pobrane
Sync folders at startup: YES
Sort and display order: pl
Library database path: C:\Users\xxx\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 8056
Listening on 192.168.1.x on port xxx
TIDAL: Connected as PREMIUM
Font size: large
Streaming
My Music
Radios
Podcasts
Startup view: My Playlists
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 10840MB
Local Audio Engine: ASIO 2
Driver version 1
Steinberg built-in ASIO Driver
Model UID:Steinberg built-in ASIO Driver
Active Sample Rate: 48kHz
Selected device:Steinberg built-in ASIO Driver
Manufacturer:
Model name: Steinberg built-in ASIO Driver
Model UID: Steinberg built-in ASIO Driver
12 available sample rates up to 1536000Hz
1411200
1536000
DSD via PCM 1.1
2 ch Float PCM 32bit little endian 44.1kHz
2 ch Float PCM 32bit little endian 48kHz
2 ch Float PCM 32bit little endian 88.2kHz
2 ch Float PCM 32bit little endian 96kHz
2 ch Float PCM 32bit little endian 176.4kHz
2 ch Float PCM 32bit little endian 192kHz
2 ch Float PCM 32bit little endian 352.8kHz
2 ch Float PCM 32bit little endian 384kHz
2 ch Float PCM 32bit little endian 705.6kHz
2 ch Float PCM 32bit little endian 768kHz
2 ch Float PCM 32bit little endian 1411.2kHz
2 ch Float PCM 32bit little endian 1536kHz
Local devices found : 14
Device #0: ASIO4ALL v2
Manufacturer:
Model UID: ASIO4ALL v2
UID: ASIO4ALL v2
Model name: ASIO4ALL v2
Device #1: Creative SB USB DSD ASIO
Manufacturer:
Model UID: Creative SB USB DSD ASIO
Model name: Creative SB USB DSD ASIO
Device #2: Creative SB USB RT ASIO
Manufacturer:
Model UID: Creative SB USB RT ASIO
Model name: Creative SB USB RT ASIO
Device #3: Realtek ASIO
Manufacturer:
Model UID: Realtek ASIO
UID: Realtek ASIO
Model name: Realtek ASIO
Device #4: Steinberg built-in ASIO Driver
Manufacturer:
Device #5: VB-Matrix VASIO-128
Manufacturer:
Model UID: VB-Matrix VASIO-128
Model name: VB-Matrix VASIO-128
Device #6: VB-Matrix VASIO-64A
Manufacturer:
Model UID: VB-Matrix VASIO-64A
Model name: VB-Matrix VASIO-64A
Device #7: VB-Matrix VASIO-64B
Manufacturer:
Model UID: VB-Matrix VASIO-64B
Model name: VB-Matrix VASIO-64B
Device #8: VB-Matrix VASIO-8
Manufacturer:
Model UID: VB-Matrix VASIO-8
Model name: VB-Matrix VASIO-8
Device #9: Voicemeeter AUX Virtual ASIO
Manufacturer:
Model UID: Voicemeeter AUX Virtual ASIO
Model name: Voicemeeter AUX Virtual ASIO
Device #10: Voicemeeter Insert Virtual ASIO
Manufacturer:
Model UID: Voicemeeter Insert Virtual ASIO
Model name: Voicemeeter Insert Virtual ASIO
Device #11: Voicemeeter Potato Insert Virtual ASIO
Manufacturer:
Model UID: Voicemeeter Potato Insert Virtual ASIO
Model name: Voicemeeter Potato Insert Virtual ASIO
Device #12: Voicemeeter VAIO3 Virtual ASIO
Manufacturer:
Model UID: Voicemeeter VAIO3 Virtual ASIO
Model name: Voicemeeter VAIO3 Virtual ASIO
Device #13: Voicemeeter Virtual ASIO
Manufacturer:
Model UID: Voicemeeter Virtual ASIO
Model name: Voicemeeter Virtual ASIO
Ethernet
UPnP devices found : 2
Device #0: WiiM
UID: uuid:xxx
Manufacturer: Linkplay Technology Inc.
Model name: WiiM xxx
Device #1: TV salon
UID: xxx
Manufacturer: Microsoft Corporation
Model name: Windows Media Player
Chromecast devices found : 2
Device #0: TV sypialnia
Model name: Chromecast
Device #1: TV salon
Model name: Smart TV Pro
Hi @sv3xxx,
When you click on the artist in Audirvāna Studio, does the picture load?
no, after opening the artist and clicking on the place for the photo, nothing either
I see, when they do not have a picture for the artist, they use the picture of the first album displayed. I will see what we can do about it
We will be able to display it here, but not in the view with all the artists, as it would require too many API calls.
