I’ve been enjoying Qobuz/Audirvana for several weeks since purchasing both. Beginning 2 days ago, upon restarting my computer, Audirvana no longer brings up my Moode pi4 device. If I CMD prompt my device, the IP address is recognized in Windows and the network. I’m able to access Moode and play the web library of stations it has available. Multiple restarts have not resolved this issue. I have included the log . In Windows settings, other devices show the Moode UPNP is not connected.
Audirvana 3.5.45
Replay Gain: by album
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\user\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1566MB
Local Audio Engine:WASAPI
Speakers (Realtek High Definition Audio)
Model UID:Speakers (Realtek High Definition Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{82beba49-d37a-4a83-90f7-3d801e80c5db}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (Realtek High Definition Audio) Manufacturer:
Model UID:Speakers (Realtek High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{82beba49-d37a-4a83-90f7-3d801e80c5db}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{82beba49-d37a-4a83-90f7-3d801e80c5db}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: D32f-F1 (Intel® Display Audio) Manufacturer: Model UID: D32f-F1 (Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2f76a363-353c-44e7-bf24-26adf4f67ace}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
