Has anyone tried to use Audirvana for streaming to moOde?
I set up moOde on a USBridge and would like to play Audirvana to moOde. After activating UPnP/DNLA in moOde, Audirvana does recognise it via Ethernet. But it would not start playing a track.
Have you used Moode before ? I was testing it a while ago with an RPi as a UPnP renderer. If memory serves, I had the same issue. Since I’ve used Moode in different scenarios I had forgotten to go into the MPD settings and select a USB output device. There had been a Digi+ Pro installed before, so the Pi was trying to output to the wrong target.
