I’ve had so many problems with buffering issues, tracks not playing properly, jumping around, cutting bits off, failing to play short tracks, but I thought it was all to do with streaming from Qobuz.
Now I have had a similar problem with local iTunes files, so it has nothing to do with Qobuz at all.
It doesn’t seem possible to put things in a play queue, move them around and delete some, without the remaining songs in the list playing wrong. This is either the end of the song not playing or the start of the next song skipping around, missing a bit, or playing for a few seconds and then stopping.
This is completely maddening, I really wish I hadn’t spent my money on this program, but not that I have, I’m going to complain until this is fixed. Properly.
Dominic
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 16384MB RAM
Registered to Dominic Perry
SoX
SW volume control: ON
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Aug 28 15:05:43 2019
Library database path: /Users/Dominic/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4454MB
Exclusive access: Disabled
Sonarworks Systemwide
Model UID:com_sonarworks_driver_SonarworksDevice:Sonarworks
UID:SonarworksEngine:0
Active Sample Rate: 192kHz
Sample rate switching latency: 0.5s
ID 0x3e ADI-2 Pro (55670186) Manufacturer:RME
Model UID:ADI-2 Pro (55670186):2A39:3FD2 UID:AppleUSBAudioEngine:RME:ADI-2 Pro (55670186):76FAF50D19B70C8:1,2
Stream ID 0x3f 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 3
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3a HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutputDP:0,1,0,1,0:0:{6904-27A1-01010101}
Device #2: ID 0x3e ADI-2 Pro (55670186) Manufacturer: RME Model UID: ADI-2 Pro (55670186):2A39:3FD2 UID: AppleUSBAudioEngine:RME:ADI-2 Pro (55670186):76FAF50D19B70C8:1,2
