Audirvana 3.5.44
Bandwidth at 0dB = 95.0178
Phase = 0
AUTO: F:\Music
Library database path: C:\Users\morei\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5592MB
Local Audio Engine:ASIO 2 driver version 1280
Vinshine DENAFRIPS USB DAC
Model UID:Vinshine DENAFRIPS USB DAC
Active Sample Rate: 192kHz
Vinshine DENAFRIPS USB DAC Manufacturer:
Model UID:Vinshine DENAFRIPS USB DAC UID:Vinshine DENAFRIPS USB DAC
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: USB DAC ASIO Manufacturer: Model UID: USB DAC ASIO UID: USB DAC ASIO
Device #1: Vinshine DENAFRIPS USB DAC Manufacturer: Model UID: Vinshine DENAFRIPS USB DAC UID: Vinshine DENAFRIPS USB DAC
