MQA stops output 3.5.38 MacOS 10/15.6
Just upgraded from 3.2.20 to 3.5.38
MQA starts playing at 24/88.2 and stops after a few seconds.
My DAC is not MQA capable yet it used to work in previous versions of Audirvana plus.
What did I wrong? Changing MQA settings (renders to decoder or no MQA supported) did not help
macOS 10.15.6 with 16384MB RAM
	Per track: OFF
SoX to DSD128 with filter type B 7th order
Sync list: 4 folders
Manual: (OFFLINE) /Volumes/Multimedia/
Manual: (OFFLINE) /Users/thomas/Desktop
Manual: (OFFLINE) /Users/thomas/Downloads
Manual: (OFFLINE) /Users/thomas/Music/Qobuz
Library database path: /Users/thomas/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 6132MB
TEAC USB AUDIO DEVICE
Model UID:TEAC USB AUDIO DEVICE:0644:8043
UID:AppleUSBAudioEngine:TEAC Corporation:UD-503:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
Limit bitdepth to 24bit: ON
ID 0x57 TEAC USB AUDIO DEVICE Manufacturer:TEAC Corporation
Model UID:TEAC USB AUDIO DEVICE:0644:8043 UID:AppleUSBAudioEngine:TEAC Corporation:UD-503:14200000:1
9 available sample rates up to 705600Hz
Stream ID 0x58 2 channels starting at 1
36 virtual formats:
54 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x57 TEAC USB AUDIO DEVICE Manufacturer: TEAC Corporation Model UID: TEAC USB AUDIO DEVICE:0644:8043 UID: AppleUSBAudioEngine:TEAC Corporation:UD-503:14200000:1
UPnP devices found : 1
Device #0: ID 0x0 Living Room UID: uuid:9ab0c000-f668-11de-9976-ac44f242c0ee Location: http://192.168.86.31:49154/MediaRenderer/desc.xml
Hello @popel75, can you disable upsampling in your audio setting?
Yes, yet same thing :
Registered to \
	Per track: OFF
AUTO: /Volumes/Multimedia/
ID 0x31 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:82 UID:AppleHDAEngineOutput:1B,0,1,1:0
Audio buffer frame size : 27 to 4096 frames
Stream ID 0x32 2 channels starting at 1
4 virtual formats:
12 physical formats
Have you tried to disconnect and reconnect your Tidal account?
Yes now there is no sound anymore, YET same thing happens when I play 16/44 files from my library. So it is a USB/DAC issue NOT Tidal related.
ā€œOnlyā€ files my DAC outputs are (16/44 etc.) upsampled DSD 64/DSD128 files from Audirvana via USB and native DSD 64/128 files from Audirvana via USB . DSD 256 only works on Windows 10 as I understood Any idea why my DAC does not output 16/44 files but only DSD files ? (PCM 44kHz is indicated yet no sound comes out of the headphone amp) merci -Thomas
and PCM 44kHz output did work on Audirvana plus …now only upsampled DSD works. Strange…
Do you still have Audirvana Plus open when you make your different test?
No I deleted it and removed it from trash, but I guess Audirvana Plus previously installed left stuff on the Mac and is the culprit. I say that because I activated a second Audirvana license on a Mojave partition where Aurdirvana Plus was never installed and all works perfectly. Moving Audirvana Plus to trash was not a good idea. Any recommendation how to delete all files (Audirvana and Audirvana Plus) and reinstall Audirvana from scratch ?
I used app cleaner and removed audirvana, a lot of audirvana plus stuff popped up to delete (such as plists and the like), now I need to wait 24 hours :frowning:
I’ll reinstall tomorrow and revert - Thomas
Audirvana Plus as a database as Audirvana 3 has, you can delete it if it has not been done yet. It’s at the same location as your actual database for Audirvana 3: Users/thomas/Library/Application Support/Audirvana
Make sure you set the MQA settings to ā€œNon MQAā€.
Yes I selected no MQA
Mojave all works as long as Tidal MQA is upsampled to DSD; 16/44 without upsampling works flawlessly and is rendered as 16/44 by the TEAC UD-503 DAC which it should.
Catalina, any file (hard drive or Tidal streaming or NAS) only works if upsampled to DSD even 16/44 has to be upsampled to be played.
As I said I removed all Audirvana and Audirvana Plus files I reinstalled Audirvana from scratch
Maybe a 10.15.6 issue, anyways a little disappointed given I paid for an upgrade and can only use it under Mojave which is an old partition on my Mac. But I like the new layout of the application, stil… :frowning:
since you are stuck with a faulty something :slight_smile:
can you try my deleting Audirvana recipe to see if it works better…
you should not having problem with Catalina.
Big text, but fast doing it…
Start fresh Audirvana by deleting those files…
If you have Playlists that are important export them first to desktop and save them in a folder… when Audirvana is reset, you can re-import them back in one shot. sadly to this day, the folders they were in if so, are not back, you have to do them again…
Before doing this, maybe you should not connect after deleting those files to Roon, Tidal or others… Install Audirvana alone with your database… if working, log to Roon or else after.
just do a ā€˜ā€˜cmd J’’ to show the folder settings preferences and see at the bottom…
Starting for new Audirvana:
Go in Audirvana preferences panel and revoke license, then remove your database(s) there
(all the folder(s) of music you have there) delete them with minus sign.
Close Audirvana.
Trash All the files in that folder (that is your database of music, back it up! or not)
Go to User… Home Folder… Library… Cookies…
Trash com.audirvana.Audirvana-Plus.binarycookies
trash com.audirvana.Audirvana-Plus.plist and
com.audirvana.Audirvana.plist in that folder
(those are A+ software preferences, back them up or not)
Go to User… Home Folder… Library… Caches… com.audirvana.Audirvana-Plus
trash the files in that folder.
Restart Mac.
This will reset pretty much Audirvana like new. You will need you serial number.
Open Audirvana, enter serial, choose a library folder at first it will sync in top middle of main window… LET IT GO, even better don’t try to adjust windows or edit files, even playing music while it is not finished… you’ll see the progress bar going… Could be long the first time depending on how large your library is, and Mac is fast or not… go to sleep if it is too long :slight_smile:
Then when finished, shut down Audirvana, yes close it before playing a song…
That way you will have your database from scratch saved without crashing.
Then copy the .sqlite file to somewhere else as a backup, then open Audirvana,
and try to play a song. it will try to install System Optimizer…
You got brand new interface and new sound… Go to Audirvana menu and select preferences…
look at them all, then click on speaker icon in the bottom right main window…
select your DAC, then the arrow right of it and look at all the preferences there too…
when all set, you can shut it down again… then you can copy the 2 prefs for the software and back them up with the database backup… if something gone wrong… you just have to put the prefs in prefs folder and the database backup to replace to faulty one… it will reopen at the time of your last database backup… so do it regurlarly if you do often editing…
when you put a backup database .sqlite, you will lose all the play counts of music files that played between the one you trash and the backup you put to replace…
so i backup up a lot the .sqlite file :slight_smile:
thanks just deleted the files (except PrivilegedHelperTools and LaunchDaemons folders that did not contain any folders or files from Audirvana), need to wait 24 hours now
Even if you revoke the license before doing it, you have to wait 24h? @Damien3 …
Yes, but I removed his computer from the database so @popel75, you can use again your license key on your device.
I have the same problem with the software stops playingšŸ˜’ I have revoke the license and reinstalled with licencekey but it says I am not allowed to do that in 24 hours😔 Is there something I can do to hurry things up?
Hello @Anders_Kruger,
I removed your computer from the database, you should now be able to activate Audirvana again.
Hello thanksšŸ˜€
Unfortunately I still have problem with audirvana stops playing randomely.
/ Anders
Can you dump the debug info here?
