MQA Volume Fixed At Max
Hi all,
I’m new to Audirvana - really like it so far and will probably stick with Studio.
Is there any software-based workaround to MQA tracks bypassing software volume control and sending a fixed/max volume to the DAC?
I do not care much if I’m not getting full MQA quality since Tidal seems to be moving away from that format anyway. Would also be happy with a solution of disabling MQA tracks from showing up in my Audirvana altogether. There are typically alternative formats within Tidal for MQA albums. Fine with playing an alternative.
Running Audirvana via USB to Gustard R26 to Emotiva power amp to Axiom towers.
Thanks!
Hi @Todj86,
Can you send us a copy of the “Debug Info” when you have this behavior? You can get it in Audirvana Settings>My account
@Antoine
Here’s the info - thanks!
Audirvana Studio 2.7.0 (20700)
Windows 11 (22621) with 12GB physical RAM
Connected account of : Timothy Olson
Available network interfaces:
SonicRacer5 ({201827d1-2e6a-42bc-b14d-332ebcb6f811}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
r8brain with 2x upsampling
Max allowed volume: 58.2418
SW volume control: ON
AUTO: C:\Users\afine\Music
Library database path: C:\Users\afine\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 234
Listening on 2600:1700:1d24:6380:67b2:1d22:3e1d:6a25 on port 61763
TIDAL: Connected as HiFi Plus
Max. memory for audio buffers: 6144MB
Local Audio Engine: WASAPI
Speakers (Gustard USB Audio 2.0)
Model UID:TUSBAUDIO_ENUM\VID_20B1&PID_3033&REV_5111&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{246d3acb-feae-4fce-8886-69cf429e1307}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Selected device:Speakers (Gustard USB Audio 2.0)
Manufacturer: Gustard
Model name: Gustard USB Audio 2.0
Model UID: TUSBAUDIO_ENUM\VID_20B1&PID_3033&REV_5111&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{246d3acb-feae-4fce-8886-69cf429e1307}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x20b1
USB Product ID: 0x3033
MQA Decoder device
DSD via PCM 1.1
Simple stereo device: No
Local devices found : 3
Device #0: VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
Manufacturer: VB-Audio Software
Model UID: VBAudioVMVAIO
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7d706fcf-6522-44e8-8757-b8f5b709c8ad}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Device #1: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0256&SUBSYS_104317EF&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{de1bb507-b383-4d60-8a7d-a390078d6ccd}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Speakers (Gustard USB Audio 2.0)
Hmm, before posting I restarted the app and it was still maxing out MQA. Tonight I closed the app again for a while, reopened Audirvana, and now the MQA settings seem to have applied as I thought they would.
The app seems to not be trying to send MQA to the DAC anymore, and software volume holds. Seems to be good for now. Thanks!
Can you try to remove the software volume control?
I think I’m all set. The NOS setting I’m trying to use on my DAC requires DAC to be at fixed volume. So currently the software volume control is my only volume control, eventually leading to a power amp (not integrated amp).
I have an SPL Volume2 arriving soon. If that doesn’t trash the sound quality, I’ll use it as a very simple preamp and run everything else at fixed volume. Thanks!
@Antoine
The same thing just happened again with an MQA file. I know for sure that I’ve played this before and the software volume control held. This time it maxed out again and stopped showing where the volume was set. Seems to be an intermittent issue.
Just closed the software and reopened. Tried the same song. Audirvana showed the volume slider active with the volume all the way down but the music left the computer at full blast.
Info:
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Max allowed volume: 96.044
Tracks with no MBID: 397
Listening on 2600:1700:1d24:6380:67b2:1d22:3e1d:6a25 on port 52321
Device: 2ch 24bits Integer, 8 bytes per frame 44.1kHz
MQA Decoder device
DSD via PCM 1.1
UPnP devices found : 1
Device #0: XBOX
UID: uuid:15942303-8799-4a1a-90cd-bbacef411cdf
Location: http://192.168.1.79:2869/upnphost/udhisapi.dll?content=uuid:15942303-8799-4a1a-90cd-bbacef411cdf
Manufacturer: Microsoft Corporation
Model name: Xbox One
Hi @Todj86,
I understand this requirement, but please try reproducing your behavior without enabling software volume control.
@Antoine
I need software volume control. The problem is that the software volume control isn’t working correctly.
If I disabled software volume control, there would not be a decreased volume to jump up from. What am I missing?
Thanks!
MQA Decoder device
You could manually set the DAC as non-MQA. When the DAC is recognized as a decoder, the original signal will be passed on to the decoder in the DAC. If you set it to no MQA in Audirvana, the core decoder of Audirvana does the first decoder step, and then you can simply use the volume control. At least that’s how it should be :wink:
