Hi Guys! newbie here, is it normal that the volume MQA is higher than the other songs on tidal. Its annoying whenever im playing my playlist when it comes to MQA the volume just jump higher. Can you help me how to fix this? Thanks in advance.
heres the debug info
macOS 10.13.0 with 8192MB RAM
Globally: ON
Replay Gain: by album
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x41 iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0x42 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 3
Device #0: ID 0x34 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x3d HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutputDP:8,5,1,0:0:{D94D-2905-01010101}
Device #2: ID 0x41 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Hello @olespaul,
This is due to the mastering of MQA file, the Replay Gain has been put during the mastering process and you have a full unfold of the MQA file with your MQA Renderer, this is why you have some volume leveling change between a track that is MQA and another that is not MQA, we can use replay gain on the non MQA file but not on the MQA file to not break MQA flow.
Hi Damien3,
Understood why but is there any nice solution to this issue? In my case MQA volume is 5-10x louder and I have to lower the volume immediately after starting to play. This is very annoying and I almost gave up using Audirvana for Tidal master quality and instead use Tidal app. I have to say this is a critical issue if your platform is known for the ability for uses to listen to the highest quality music files with ease.
