With multi-outs interfaces (SSL etc…) is it possible to choose output channel pair (for example, 3-4 instead of 1-2 default) ?
If not, it’s a suggested future feature !
Hi @clabbe,
It should be, when you click on the output menu, you should have all the different channel mapping available for your output.
Yes, i can see all my interfaces but not the channel pairs inside individual interface. That’s what i would like for my 2x2 outputs SSL interface.
Can you send us a copy of the "Debug Info“ ? You can get it in Audirvana Settings>My account.
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content. All you have to do is paste it in response to this message.
Audirvana Origin 2.5.12 (20512)
macOS Version 13.6 (assemblage 22G120) with 8GB physical RAM
Connected account of : Christophe LABBE
AUTO: /Users/christophelabbe/Music/Music/Hi-Res
Library database path: /Users/christophelabbe/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49431
Font size: regular
Language: Langue du système
Ma Musique
Bibliothèque
Startup view: Ma Musique : Albums
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: yes
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Solid State Logic SSL 2+
Model UID:SSL 2+:31E9:0002
UID:AppleUSBAudioEngine:Solid State Logic:SSL 2+:2400000:1,2
Selected device:SSL 2+
Manufacturer: Solid State Logic
Model name: Solid State Logic SSL 2+
Model UID: SSL 2+:31E9:0002
UID: AppleUSBAudioEngine:Solid State Logic:SSL 2+:2400000:1,2
USB Vendor ID: 0x31e9
USB Product ID: 0x0002
ID 0x35
Multichannel: 4 channels
Channel bitmap: Oxf, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Number of channels: 4
Simple stereo device: No
Number of active channels: 4, in 1 stream(s)
Stream ID 0x36 4 channels starting at 1
12 virtual formats:
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
12 physical formats
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
Local devices found : 5
Device #0: ID 0x69 PL2493Q
Manufacturer: IVM
Model UID: 26CD6A61-0000-0000-0B21-010380351E78
Model name: IVM PL2493Q
Device #1: ID 0x35 SSL 2+
Device #2: ID 0x63 Haut-parleurs Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs Mac mini
Device #3: ID 0x3a NoMachine Audio Adapter
Manufacturer: NoMachine
Model UID: NMAudioDevice_ModelUID
UID: NMAudioDevice_UID
Model name: NoMachine Audio Adapter
Device #4: ID 0x45 NoMachine Microphone Adapter
Model UID: NMAudioMicDevice_ModelUID
UID: NMAudioMicDevice_UID
Model name: NoMachine Microphone Adapter
If you look at this device in the Audio Midi setup app of MacOS, can you choose the output channel pair?
In the Audio/MIDI setup of Mac OS, i can see the 4 output channels, but cannot choose ch3-4 as the default output for Mac standard applications.
On the other hand, i’m free to select my output channels and to make any channel routing in my DAWs (Logic Pro, Universal Audio LUNA and Harrison Mixbus).
If you have a convolution software you can change the output channels with the .cfg file.
