I only have one actual file, but the local directory shows the same track multiple times.
Update to latest version, delete the database and add the folders again.
Stop Audirvana and delete the database, is here:
Audirvāna database and log files are in ~/.local/share/audirvana
Can I just plug my SD in to SD card reader and delete from windows? I don’t have ssh to find it that way. I’m using gentooplayer.
Try it, it should work.
