I have multiple issues during playback:
If a song with higher sampling rate is played after one with lower the song is played slower, like a record for 45rpm played at 33rpb. In my case a 24bit/96kHz file is played after one with 16bit/44kHz. You can hear an example in the linked file: [iCloud Drive - Apple iCloud ]
Player stops during playing
In the middle of the song the player jumps to the next song. See debug files
My configuration is:
Audirvana Studio on dedicated Mac mini (M1, 16GB) (newest OS and Audirvana), WiFi over dedicated WLAN, WiFi5
Primare SC15 MK2 (newest firmeware) connected via UPnP, Ethernet CAT8.1 connected with the same access point, where the WiFi of the Mac mini is available.
same issues with Ethernet only
You are restricting the SC15 MK2 playback potentials by employing UPnP which is restricted to 24/192kHz and DSD128ā¦
With USB B you can playback PCM to 384kHz⦠The problem with DSD playback using USB with the Primare box is that the SC15 MK2 does not support DoP (DSD over PCM) file playback.
Digital inputs
3 x Optical/TOSLINK 192kHz/24bit
1 x SPDIF/RCA 192kHz/24bit
1x USB-A up to 192kHz/24bit; up to DSD128 (5.6MHz)
1x USB-B up to 384kHz/24 bit; DSD256
8 available sample rates up to 5644800Hz
5644800
Volume control: Yes
Raw DSD (msb)
Debug Info
Audirvana Studio 2.10.2 (21002)
macOS Version 15.5 (Build 24F74) ARM64 with 16GB physical RAM
Connected account of : Istvan Densagined
Local network access: allowed
Max allowed volume: 89.899
Manual: (OFFLINE) /Volumes/Medien Server/Media/Music
Sync folders at startup: NO
Sort and display order: de
Library database path: /Users/audirvana/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 3258
Listening on on port 49586
TIDAL: Connected as PREMIUM
Font size: regular
Language: Systemsprache
Streaming
Meine Musik
Radios
Podcasts
Lokal
Startup view: Eigene Wiedergabelisten
Use Apple Remote: yes
Number of paired remotes: 3
Screen saver disabled: yes
Active method: UPnP
Selected Network interface: WLAN
WLAN
Preferred device: [UPnP] Primare SC15 MK2 Model UID:Primare SC15 Prisma MK2 UID:uuid:01efd6d8-ce86-11ef-a6a3-018a47a8cbbc
Selected device:Primare SC15 MK2
Manufacturer: Primare
Model name: SC15 Prisma MK2
Model UID: Primare SC15 Prisma MK2
UID: uuid:01efd6d8-ce86-11ef-a6a3-018a47a8cbbc
UPnP device at http://192.168.1.125:38400/description.xml
ID 0x0
5644800
Volume control: Yes
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get:*:audio/flac:*
http-get:*:audio/x-flac:*
http-get:*:audio/wav:*
http-get:*:audio/x-wav:*
http-get:*:application/ogg:*
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO
http-get:*:audio/aiff:*
http-get:*:audio/x-aiff:*
http-get:*:audio/dsd:*
http-get:*:audio/x-dsd:*
DLNA 1.5: Yes
Native Gapless playback: Yes
Can play native DSD: Yes
Volume Control: scalar
16 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:02:43.000
CurrentURI: http://192.168.1.177:49152/audirvana/audio_f_92.wav
CurrentURIMetadata: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">
<item id="92" parentID="0" restricted="1">
<dc:title>Ain't No Sunshine</dc:title>
<dc:creator>Nancy Sinatra</dc:creator>
<upnp:artist>Nancy Sinatra</upnp:artist>
<upnp:genre></upnp:genre>
<upnp:albumArtURI>http://resources.tidal.com/images/3801283b/5dcb/4ded/925a/f57691ba2547/640x640.jpg</upnp:albumArtURI>
<upnp:album>Cherry Smiles - The Rare Singles</upnp:album>
<upnp:originalTrackNumber>4</upnp:originalTrackNumber>
<upnp:class>object.item.audioItem.musicTrack</upnp:class>
<res duration="0:02:43.000" size="28788524" protocolInfo="http-get:*:audio/wav:DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000" sampleFrequency="44100" bitsPerSample="16" nrAudioChannels="2">http://192.168.1.177:49152/audirvana/audio_f_92.wav</res>
</item>
</DIDL-Lite>
nextURI: http://192.168.1.177:49152/audirvana/audio_f_95.wav
<item id="95" parentID="0" restricted="1">
<dc:title>For What It's Worth</dc:title>
<dc:creator>Sergio Mendes</dc:creator>
<upnp:artist>Sergio Mendes</upnp:artist>
<upnp:albumArtURI>http://resources.tidal.com/images/17ae2723/a28d/47d5/87d8/60c49bdbfa0c/640x640.jpg</upnp:albumArtURI>
<upnp:album>Stillness</upnp:album>
<upnp:originalTrackNumber>7</upnp:originalTrackNumber>
<res duration="0:03:43.000" size="39367820" protocolInfo="http-get:*:audio/wav:DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000" sampleFrequency="44100" bitsPerSample="16" nrAudioChannels="2">http://192.168.1.177:49152/audirvana/audio_f_95.wav</res>
</item>
</DIDL-Lite>
PlayMedium: NETWORK
Current transport actions:
Play,Stop,Seek,X_DLNA_SeekTime
<?xml version="1.0"?>
<root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:qq="http://www.tencent.com">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC>
<qq:X_QPlay_SoftwareCapability>QPlay:2</qq:X_QPlay_SoftwareCapability>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
<friendlyName>Primare SC15 MK2</friendlyName>
<manufacturer>Primare</manufacturer>
<manufacturerURL>http://www.primare.net/</manufacturerURL>
<modelDescription>PrimareDMR</modelDescription>
<modelName>SC15 Prisma MK2</modelName>
<modelNumber>2.0</modelNumber>
<modelURL>https://primare.net/product/sc15-prisma-preamplifier-and-network-player/</modelURL>
<serialNumber>1234567890</serialNumber>
<UDN>uuid:01efd6d8-ce86-11ef-a6a3-018a47a8cbbc</UDN>
<presentationURL>http://192.168.1.125</presentationURL>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
<SCPDURL>/RenderingControl.xml</SCPDURL>
<controlURL>/RenderingControl</controlURL>
<eventSubURL>/RenderingControl/eventSub</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
<serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
<SCPDURL>/AVTransport.xml</SCPDURL>
<controlURL>/AVTransport</controlURL>
<eventSubURL>/AVTransport/eventSub</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<SCPDURL>/ConnectionManager.xml</SCPDURL>
<controlURL>/ConnectionManager</controlURL>
<eventSubURL>/ConnectionManager/eventSub</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-tencent-com:service:QPlay:1</serviceType>
<serviceId>urn:tencent-com:serviceId:QPlay</serviceId>
<SCPDURL>/QPlay.xml</SCPDURL>
<controlURL>/QPlay</controlURL>
<eventSubURL>/QPlay/eventSub</eventSubURL>
</service>
</serviceList>
</device>
<URLBase>http://192.168.1.125:38400</URLBase>
</root>
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<serviceList>
<service>
</service>
<service>
</service>
<service>
</service>
<service>
</service>
</serviceList>
</device>
</root>
UPnP devices found : 1
Device #0: ID 0x0 : Primare SC15 MK2
Local Audio Engine: CoreAudio
Device #0: ID 0x47 Mac mini-Lautsprecher
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Mac mini-Lautsprecher
Chromecast devices found : 2
Device #0: Primare SC15 MK2
Model name: Primare SC15 MK2
Device #1: [LG] webOS TV OLED55B4ELA
Model name: OLED55B4ELA.DEUQLJP
Syslog is a problem. The Syslog file has about 9000 lines.
Agoldnear:
ynchronization problem⦠The DAC is not recognizing the sample-rate metadata about the new fileā¦
Simplify your playback scenario and connect the Primare box directly to the MacMini via Ethernet and your music library connected locally via USB
Please paste your debug information here so folks can help as best possibleā¦
I personally donāt want to go to iC
I cannot connect the streamer directly to the Mac Mini via Ethernet - It doesnāt work. Or do you mean, connect both via Ethernet with the local network. I already tried this, same problems. No playback problems with USB.
I donāt have (play) local music. Everything is streamed via Tidal.
I think itās a buggy network implementation of the streamer.
I donāt have any material with 384kHz sampling rate, or in DSD. Iām just streaming via Tidal. So why I restrict the streamer?
But āYesā I donāt have any of these issues if I use USB connection. But the sound is better via Ethernet. But to be honest I donāt use a good USB cable.
Jud
May 19, 2025, 6:01am
9
What worked for me with #3 was the setting for playback skips, but I see from your debug info you already have that setting activated. I am sorry that I donāt have other ideas.
Hi @Densagined ,
Which output are your using on your SC15 MK2? Analog or Coax?
Ok, I donāt have an MK2 here at the office (I have the first version of SC15), but will try to reproduce your issue as soon as possible.
I can reproduce it with this two songs, streamed via Tidal:
First song : You Inspire Me by FM LAETI on TIDAL
Second song: Don't Blame Me by Charles PAsi on TIDAL
If you can connect the streamer to your router via Ethernet you can connect the streamer directly to the MacMini via Ethernet. ⦠If you think it is a problem with the Primare box, what do the Primare folks say about this behavior?
You may like to take advantage of AudirvÄnaās capability to up-sample PCM to 352.8kHz and 384kHz ⦠This will help maximize the potentials of the ESS chipset employed in the DAC platform topology.
How long is your USB cable? ā¦It should be a meter or less and of decent quality. Also, I think you said you were using USB-C, are you using an adapter to the USB port(s) on the Primare box? ⦠If you are using an adapter, I suggest replacing it with this on a USB3.0 cable:
The problem is, if I connect the streamer via Ethernet and give both a fixed IP-Adress I donāt have access to the Internet. Because the Mac mini will prioritize the Ethernet connection to search for music (Tidal). If I change the order, the WiFi will be prioritized, and the connection to the streamer is lost. Do you know how to bridge both networks?
Do you use the UPnP output option or the Chromecast output option in Audirvana? I had some issues with the Primare Prisma platform where those two output options seems to be āfighting each otherā in the past.
What solved it for me was putting a switch after the router and connect both the primare device and the computer to the switch.
Maybe an option to try?
Oh man. You can call me a Dummy. Itās soooo easy. I never expect what this works out of the box.
I have configured so many networks with routers and managed switches, VLANS and firewalls, the I oversee simple solution.
Easy steps to reproduce:
Configure Mac mini and Stream with fixed IPs from a different network.
Select the streamer in Audirvana
Change the order of the network services: Put WiFi above Ethernet.
Be happy.
Thanks to widen my horizon.
Now I will start testing again.
BTW: Chromecast server is not available anymore.
Mac mini is beside the streamer. Cable is just 30cm.
I got feedback from Primare too. They asked me to activate the Universal Gapless Playback⦠Currently I have no problems any more. Both solutions Ā»direct Ethernet connection between Mac and DACĀ« and USB works without problems so far. I donāt know whatās happen if I go back to original setup, but why should I do this
