Hi question for Audirvana or user,
I really like the software but need it to work across 3 machines all working at the same time… If I purchase 3 licenses will I be able to have the 3 machines synchronize the library / playlists with each other if the library is on a business dropbox
Thank you
Hi @bel710,
If they are simultaneously opened at the same time, you won’t be able to do so, as the database file will be locked for one when the other is trying to access it.
