Here it is, thanks.
Audirvana Mac Version 3.5.40 (3570)
macOS 10.15.6 with 40960MB RAM
Registered to Ron Ackermann
AUTO: /Volumes/MusSync1/MUS
Library database path: /Users/aaron8489/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: LUMIN D2:LUMIN Model UID:Pixel Magic Systems Ltd. LUMIN D2:LUMIN UID:uuid:4c494e4e-3d9b-11e1-b86c-0016e8089cd6
UPnP device at http://192.168.1.6:23000/
ID 0x0 LUMIN D2:LUMIN Manufacturer:Pixel Magic Systems Ltd.
Volume control: No
DSD capability: Raw DSD (MSB)
http-get:::*
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp4:
http-get::audio/mpeg4-generic:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aac:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/octet-stream:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
32 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
0 physical formats
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI: /tmp/raataudio
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?>
1
0
GetCurrentTransportActions
InstanceID
in
A_ARG_TYPE_InstanceID
Actions
out
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
AVTransportURIMetaData
NextURI
out
NextAVTransportURI
NextURIMetaData
out
NextAVTransportURIMetaData
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Next
InstanceID
in
Pause
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Previous
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
SetAVTransportURI
InstanceID
in
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
Stop
InstanceID
in
CurrentPlayMode
string
NORMAL
NORMAL
REPEAT_ONE
REPEAT_ALL
SHUFFLE
SHUFFLE_NOREPEAT
RecordStorageMedium
string
NOT_IMPLEMENTED
LastChange
string
string
CurrentTrackURI
string
string
string
NOT_IMPLEMENTED
string
i4
i4
ui4
AVTransportURI
string
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
NO_MEDIA_PRESENT
string
NextAVTransportURI
string
string
NOT_IMPLEMENTED
CurrentTrack
ui4
0
65535
1
string
string
string
NONE
UNKNOWN
CD-DA
HDD
string
string
NOT_IMPLEMENTED
string
NONE
UNKNOWN
CD-DA
HDD
string
NumberOfTracks
ui4
0
65535
A_ARG_TYPE_SeekMode
string
REL_TIME
TRACK_NR
string
string
NOT_IMPLEMENTED
TransportStatus
string
OK
ERROR_OCCURRED
TransportPlaySpeed
string
1
1
1
LUMIN D2:LUMIN
http://www.luminmusic.com/
LUMIN
D2
1.0
DMR-1.50
image/png
120
120
24
/images/lumin-120x120.png
image/png
48
48
24
/images/lumin-48x48.png
/AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
/ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
/RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Product:1
urn:av-openhome-org:serviceId:Product
/Product/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Product/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Product/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Playlist:1
urn:av-openhome-org:serviceId:Playlist
/Playlist/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Playlist/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Playlist/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Time:1
urn:av-openhome-org:serviceId:Time
/Time/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Time/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Time/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Info:1
urn:av-openhome-org:serviceId:Info
/Info/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Info/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Info/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Volume:1
urn:av-openhome-org:serviceId:Volume
/Volume/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Volume/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Volume/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Transport:1
urn:av-openhome-org:serviceId:Transport
/Transport/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Transport/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Transport/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:magictv-com:service:MagicAudio:1
urn:magictv-com:serviceId:MagicAudio
/MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Credentials:1
urn:av-openhome-org:serviceId:Credentials
/Credentials/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Credentials/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Credentials/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Radio:1
urn:av-openhome-org:serviceId:Radio
/Radio/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Radio/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Radio/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
urn:av-openhome-org:service:Receiver:1
urn:av-openhome-org:serviceId:Receiver
/Receiver/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/scpd.xml
/Receiver/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/control.xml
/Receiver/4c494e4e-3d9b-11e1-b86c-0016e8089cd6/event.xml
UPnP devices found : 3
Device #0: ID 0x0 DietPi UID: uuid:ed987da7-8247-4ac6-ac0e-f58a33c89e02 Location: http://192.168.1.11:49494/description.xml
Device #1: ID 0x0 LUMIN D2:LUMIN UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e8089cd6 Location: http://192.168.1.6:23000/
Device #2: ID 0x0 Rons-iMac.local UID: uuid:9c07c846-c0b0-bd47-ab19-71faaa28dfa0 Location: http://192.168.1.15:52101/DeviceDescription.xml
Max. memory for audio buffers: 39936MB
Device #0: ID 0x4b iMac Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
