During the songs but not in interval between songs , my Audirvana creeps.
I changed cables , disconnect DAC , but creeps continue.
With others players like VLC no problems.
Thanks for helping me.
Hello,
you don’t give much info…
Is this from a new A+ install or it was working before and now it “creeps”… you have another word for creeps…
if it was ok before with A+ recheck those… in audio midi setup if you see your DAC for output
In A+ pref panel audio… check if you see your dac up there… exclusive access…
you can try Closing A+, deleting your A+ preferences and restart the mac, and reload your preferences when opening A+…
trash com.audirvana.Audirvana-Plus.plist in that folder (those are A+ software preferences)
Hallo ,
the screens that appears to me are a lot different from listed to you.Aniway ,
my parameters are :
iMac 21 high-sierra 10.13.3
Audirvana 3.2.6 (3137)
The DAc is Audioengine D1.
I use Senn HD598 and HD800 but with the same crackle.
Could be the right word is crackle very disturbing.
Sometimes , i think from the version Audirvana 3 has done , but rarely.
Now the crackle is continue , but not when the music stop.
Sorry , what do you mean: “deleting your A+ preferences” ?
After Command J : USER - Library - Application support - Folder Audirvana - 4 files
Have i to delete the folder Audirvana or the 4 files?
it means to put them to trash…
Not there…
Before stop A+
go here:
after restart Mac, and restart A+ and put back your DAC in the settings
Hallo , it is not clear.
I did as you suggest and now not always crackle with Audirvana but when using VLC or Quick Time Player (with the same DAC) is always good.
Could be a good idea if you send me a clean version of Audirvana 3.2.6 ?
Tomorrow i’m testing other players and will report to you.
Good night.
I am already connect with Audirvana , from two years.
Why “try now” the program?
Anyway this morning it seems not crackle.
Did you update this morning with a correct version?
Try now is to download last version of A+, like you wanted… I am not Damien (the developper), just a user
Ok , so double thanks for your help! I intender you were of the Audirvana staff!
