Yes. The same problem.
Another DAC “beyerdynamic impacto” have no problems on this MacBook with same settings. It plays well in DoP mode. Both 1.0 and 1.1.
What kind of DSD file are you playing and what does the DAC support?
“ can connected to windows, iOS, Android system with usb, supporting up to 32Bit/384khz PCM signal, DSD 256 signal, 32Bit/384KHz DXD signal…”
“Support PC USB audio decoding functions, work in asynchronous transfer mode, support support up to 32Bit/384KHz PCM signa, support up to 1bit/11.28MHz DSD signal, work in DOP or native mode”
I try to use dsd 128. (Dsf format file).
If it supports 256, you can use up to 128 in DoP.
Does the Beyer support 512?
Can you please send your order reference so I can find you in our database?
He won’t…
TNT Team = Pirate
