I’m wondering why the Audirvana settings say my device SMSL USB Audio doesn’t support native DSD?
You selected dsd over pcm 1.1 in dac preferences little speaker icon at bottom right of main window?
Yes I had no choice because the settings says native DSD not supported.
I’m wondering do I need to update the USB firmware for this SMSL M500 DAC. I’m having trouble doing that on my MAC.
Hers my debug info:
macOS 11.2.1 with 8192MB RAM
Registered to Anthony Ford
Sync list: 5 folders
AUTO: /Users/anthonyford/Music/Converted ALAC
AUTO: /Users/anthonyford/Music/DSD
AUTO: /Users/anthonyford/Music/FLAC music
AUTO: /Users/anthonyford/Music/NativeDSD
AUTO: /Users/anthonyford/Music/iTunes/iTunes Media/Music
Library database path: /Users/anthonyford/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 6798MB
SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1
Active Sample Rate: 768kHz
ID 0x3e SMSL USB AUDIO Manufacturer:SMSL
Model UID:SMSL USB AUDIO:152A:85DD UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1
Audio buffer frame size : 231 to 4096 frames
MQA Decoder device
Stream ID 0x3f 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3e SMSL USB AUDIO Manufacturer: SMSL Model UID: SMSL USB AUDIO:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1
OK maybe I’m misunderstanding . If I choose DSD over PCM1.1, then that is using Native DSD? I thought there was a setting for raw Native DSD so that I didnt have to convert to PCM?
Audirvana doesn’t detect every dac in the world by default… mine isn’t either, i select dsd over pcm 1.0, because my dac stop at dsd128 if yours go further, select dsd over pcm 1.1. It is dsd playing, not converted, you can surely see that on your dac window when audirvana is playing
Thank you that helps grow my knowledge of this software. I still have a question though. Why is only PCM formats shown on my debug window? Shouldn’t I be able to play DSD formats directly?
SMSL USB AUDIO… Every input port supported DSD streaming, coaxial and optical supported to DSD64 by DoP technology via 24bit/176.4kHz SPDIF frame… Amazon your dac?
Your Debug:
Here is my debug while playing a DSD64 file… my dac is directly connected by USB
on my DAC window it is DSD64 playing
can’t tell you more… Maybe @Antoine or others can help you more with Debug
Registered to Xxxxxx
AU plugin #0: Music Effect - FabFilter FF Pro-Q 2 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 24
Filter max length = 512000
Cut-Off (x Nyquist) = 97%
Phase = 68%
AUTO: /Volumes/MUSIC/MUSIC
Library database path: /Users/xxxxx/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 13388MB
32bit 384kHz DSD Interface
Model UID:32bit 384kHz DSD Interface:27F7:1301
UID:AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz DSD Interface:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
ID 0x29 32bit 384kHz DSD Interface Manufacturer:Wyred 4 Sound
Model UID:32bit 384kHz DSD Interface:27F7:1301 UID:AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz DSD Interface:413-001:2
16 virtual formats:
16 physical formats
Device #0: ID 0x3c Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x29 32bit 384kHz DSD Interface Manufacturer: Wyred 4 Sound Model UID: 32bit 384kHz DSD Interface:27F7:1301 UID: AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz DSD Interface:413-001:2
Audirvana display on my TV from Mac Mini without screen USB connect to DAC
DSD shown in, out, from Audirvana to dac display also…
Thank you for this. I’ve just discovered also on another post that MAC doesn’t support native DSD. So that’s why I can’t see it in the debug info I suppose.
Have you installed the ASIO USB driver?
No. Is there a dedicated USB driver for better data transfer to my DAC? Can you give me some more information?
You can download the Windows USB driver from here:
https://www.smsl-audio.com/upload/portal/20200511/202005111058548271.rar
Also make sure you’re running the latest firmware version.
Its a Mac and yes I have the latest firmware for that device thanks.
On the Mac just select DoP 1.1. You should be good up to DSD256.
Yes Thank you I’m really just wondering is there a loss of quality in not having native DSD and converting to PCM because of limitations of the MAC .
DoP is not converting to PCM. It‘s just packaging native DSD stream in PCM words.
Ok not sure what that means but it sounds like conversion to me. I will keep researching but haven’t decide whether purchasing DSD music is any better than PCM if I continue using Audirvana and my mac.
Nope, it just packs the unaltered DSD stream in PCM data packets. There is a a header that identifies it as DSD so that the receiving DAC can extract the DSD content.
Good day. Dac (xduoo xd-05 basic).
Audirvāna settings DoP 1.0 no sound.
Debug info:
Audirvana Mac Version 3.5.46 (3576)
macOS 12.2.0 with 8192MB RAM
Registered to TNT team
Per track: OFF
Replay Gain: by track
Manual: (OFFLINE) /Volumes/SanDisk/MUSIC-HI-RES
iTunes/Music library synchronization: last synchronized on Sun Jan 30 20:42:15 2022
Library database path: /Users/egor/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2348MB
Exclusive access: Disabled
xDuoo USB Audio 2.0
Model UID:xDuoo USB Audio 2.0:152A:8807
UID:AppleUSBAudioEngine:xDuoo USB Audio 2.0:xDuoo USB Audio 2.0:14100000:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
ID 0x66 xDuoo USB Audio 2.0 Manufacturer:xDuoo USB Audio 2.0
Model UID:xDuoo USB Audio 2.0:152A:8807 UID:AppleUSBAudioEngine:xDuoo USB Audio 2.0:xDuoo USB Audio 2.0:14100000:1
Stream ID 0x67 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 4
Device #0: ID 0x3d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:51 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x66 xDuoo USB Audio 2.0 Manufacturer: xDuoo USB Audio 2.0 Model UID: xDuoo USB Audio 2.0:152A:8807 UID: AppleUSBAudioEngine:xDuoo USB Audio 2.0:xDuoo USB Audio 2.0:14100000:1
Device #2: ID 0x2b Audiojingle Manufacturer: Audiojingle x Software Model UID: Soundtree UID: com.audiojinglex.soundtree.mastereffect
Device #3: ID 0x31 Audiojingle (UI Sounds) Manufacturer: Audiojingle x Software Model UID: Soundtree_UISounds UID: com.audiojinglex.soundtree.mastereffect.UISounds
Have you tried with exclusive acces on?
