Need help with HLC
Yesterday I wanted to load some correction files into HLC, when I discovered that the HLC screen does not appear at all. I use two plugins: U-BACCH and HLC.
The U-BACCH window appears, but the HLC window remains empty. In settings I can configure HLC, but while playing music I cannot switch filters because the window remains empty. Fortunately, HLC works, even though it is not visible.
When I uninstall U-BACCH, the HLC window appears and everything works correctly. The strange thing is that if I uninstall and reinstall both plugins, both plugins appear, but as soon as Audirvana is restarted, the HLC window no longer appears. How do I solve this? It’s not a big problem, except I can’t change filters on the fly.
Hi @Cornelius,
Audirvana Studio 2.8.2 (20802)
Windows 11 (22631) with 32GB physical RAM
Connected account of : Cornelis Huizinga
Available network interfaces:
Ethernet ({f1b9e239-5399-4c80-b7f8-27533d5c768c}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
	VST3 plugin #0: C:\Program Files\Common Files\VST3\BACCH Laboratories\uBACCHaudio.vst3
		ClassID: ABCDEF019182FAEB4241434855626163
	VST3 plugin #1: C:\Program Files\Common Files\VST3\HLConvolver.vst3
		ClassID: ABCDEF019182FAEB4D616E754F6E6765
	VST3 plugin #2: None
	VST3 plugin #3: None
Sync list: 2 folders
AUTO: D:\klassiek
AUTO: D:\pop
Library database path: C:\Users\keesh\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
D:\klassiek
Deep Synch: yes
Scanning 7877/8285: D:\klassiek\gitaar\Baden Powell - The Legendary MPS Albums (2008) [FLAC] {2 CD}\CD1\03. Round midnight.flac
Folders queued for synchronization:
D:\pop
Deep Synch: yes
Tracks with no MBID: 8443
Listening on 192.168.1.162 on port 49748
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Use media keys for volume control: no
Number of paired remotes: 2
Screen saver disabled: yes
Max. memory for audio buffers: 16384MB
Luidsprekers (DAC8 PRO)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_88C4&REV_0150&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{03754d4a-67e6-4bb3-81c7-15ac6d1e45f3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Luidsprekers (DAC8 PRO)
Manufacturer: Okto Research
Model name: DAC8PRO
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_88C4&REV_0150&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{03754d4a-67e6-4bb3-81c7-15ac6d1e45f3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x152a
USB Product ID: 0x88c4
Kernel Streaming capable
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
8 ch Integer PCM 32bit little endian 44.1kHz
8 ch Integer PCM 32bit little endian 48kHz
8 ch Integer PCM 32bit little endian 88.2kHz
8 ch Integer PCM 32bit little endian 96kHz
8 ch Integer PCM 32bit little endian 176.4kHz
8 ch Integer PCM 32bit little endian 192kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 44.1kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 48kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 88.2kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 96kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 176.4kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 192kHz
8 ch Integer PCM 16bit little endian 44.1kHz
8 ch Integer PCM 16bit little endian 48kHz
8 ch Integer PCM 16bit little endian 88.2kHz
8 ch Integer PCM 16bit little endian 96kHz
8 ch Integer PCM 16bit little endian 176.4kHz
8 ch Integer PCM 16bit little endian 192kHz
Local devices found : 3
Device #0: Realtek Digital Output (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1458A182&REV_1003
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{57f9b741-15bc-46e1-93b8-9aaecf7ecfee}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Luidsprekers (DAC8 PRO)
Model name: DAC8PRO
Device #2: SAMSUNG -2 (Intel(R) Display Audio)
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{9a07354e-4522-4be6-87d7-e1d09c8aef72}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0: [TV] Samsung Q90 Series (65)
UID: uuid:d7b02e68-d124-4ffa-b841-3bfd84bb9cb1
Manufacturer: Samsung Electronics
Model name: QE65Q95TDTXXN
Have you tried to enable the option “Use as Stereo device”?
i tried, but HLC is still invisible
This morning I reinstalled the HLC and U-BACCH plugins in Audirvana and selected “Use as Stereo device” and to my delight everything worked correctly, even after restarting Audirvana. Antoine, thank you very much again for your help
