Iām a long time Audirvana customer. Usually using my MacMini but when I noticed that there was a version for Synology I really wanted to try it out (MacMini is old and dying and I have a pretty much new Synology).
Synology DS 920+ with 8GB of RAM.
I installed the Synology package and at this point Iām able to access Audirvana on Syno using the App (had to deactivate the firewall to do so).
At the moment Iām stuck at adding my USB DAC. The Synology do see and recognized my USB DAC in Syno Info Center. But in the Remote, in settings, in output device, there is only my LG TV and nothing else in the list and the available network interface are eth1 or eth0.
Thatās what I thought. When we developed the development of Synology version, we saw the difference with the QNAP version, and in fact the Synology doesnāt support USB Audio
At least Iām not crazy, and it does explain why I wasnāt able to make it work.
The mention of Synology DSM7 should be removed from the website, Iām assuming that I wont be the only one who will try to go through that mystical path.
I will then wait that my old MacMini die and simply replace it. Btw, itās off topics but would 8GB RAM enough for a new MacMini only dedicated to Audiravana?
