Every time NUC starts
Can you check the database integrity using the command in the Maintenance section of the preferences page?
If it fails, then you may want to restore from a backup, or delete the file AudirvanaPlusDatabaseV2.sqlite to restart from scratch.
It is located in ~/Library/Application Support/Audirvana
To access ~/Library with the Finder, you can use its Go menu while pressing the option (or alt) key. This reveals the Library command in this Go menu.
Special Warning : When you delete the file AudirvanaPlusDatabaseV2.sqlite, you will lose all the Playlists you created in Audirvana. However, you can back-up all those Playlists by exporting them before deleting the database file.
Worked for me.
thank you
I had to update the library database, everything goes normal. After turning on the Tidal login window no longer shows.
The problem with version 3.5.10 solved this. Tidal remained logged in.
yes. sorry for late reply, didn’t know i had a response to my question. every time i open audirvana, the login screen opens for tidal and i have to enter my login details along with a captcha every single time.
I am on windows 10. latest updated version of audirvana
