I tried to post the log in this response, but got:
“Sorry, new users can only put 5 links in a post.”
I sent the log in a return reply to your email.
I changed your profile settings, you should be able to do it now.
Thanks.
macOS 10.15.5 with 16384MB RAM
Sync list: 2 folders
AUTO: /Volumes/Media Available/Old Time Radio
AUTO: /Volumes/Media Available/iTunes/iTunes Media/Music
Library database path: /Users/imac-21/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Preferred device: RR2160_192.168.4.101 Model UID:Outlaw RR2160_192.168.4.101 UID:uuid:6CBAc1b3-ed59-1900-4530-0022D9106CBA
UPnP device at http://192.168.4.58:49494/description.xml
ID 0x0 RR2160_192.168.4.58 Manufacturer:Outlaw
Model UID:Outlaw RR2160_192.168.4.58 UID:uuid:6CBAc1b3-ed59-1900-4530-0022D9106CBA
Volume control: No
http-wavetunes::audio/x-ms-wma:*
http-get::audio/3gpp2:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/flac:
http-get::audio/x-flac:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration:
CurrentURI:
CurrentURIMetadata:
nextURI: http://192.168.4.25:49152/audirvana/audio_1_6.wav
nextURIMetadata:
dc:titleOne Hour</dc:title>
dc:creatorColeman Hawkins</dc:creator>
upnp:artistColeman Hawkins</upnp:artist>
upnp:genreJazz</upnp:genre>
upnp:albumColeman Hawkins: 1929-1934</upnp:album>
PlayMedium: NOT_IMPLEMENTED
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData Stop InstanceID in A_ARG_TYPE_InstanceID SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData TransportStatus string OK ERROR_OCCURRED vendor-defined NextAVTransportURI string NextAVTransportURIMetaData string CurrentTrackMetaData string RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_SeekTarget string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined RelativeTimePosition string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_ALL INTRO NORMAL TransportPlaySpeed string 1 vendor-defined PossiblePlaybackStorageMedia string AbsoluteTimePosition string CurrentTrack ui4 0 4294967295 1 CurrentTrackURI string CurrentTransportActions string NumberOfTracks ui4 0 4294967295 AVTransportURI string AbsoluteCounterPosition i4 CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED vendor-defined CurrentMediaDuration string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME ABS_COUNT REL_COUNT TRACK_NR CHANNEL_FREQ TAPE-INDEX FRAME AVTransportURIMetaData string RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED LastChange string CurrentTrackDuration string TransportState string STOPPED PLAYING TRANSITIONING PAUSED_PLAYBACK PAUSED_RECORDING RECORDING NO_MEDIA_PRESENT PossibleRecordQualityModes stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 RR2160_192.168.4.58 Outlaw 0.0.1-git RR2160 0.0.7-git uuid:6CBAc1b3-ed59-1900-4530-0022D9106CBA image/png 64 64 24 /upnp/grender-64x64.png image/png 128 128 24 /upnp/grender-128x128.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 http://192.168.4.58:49494/UPnP devices found : 26
Device #0: ID 0x0 Heos-Bedroom-L UID: uuid:6b378267-14c1-16fc-0080-0005cd3bd767 Location: http://192.168.4.23:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Heos Bathroom UID: uuid:4b33f904-4b57-1507-0080-0005cd526996 Location: http://192.168.4.22:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 Heos Kitchen UID: uuid:90be851e-20f8-107a-0080-0005cd522e22 Location: http://192.168.4.21:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 HEOS-Bedroom-R UID: uuid:1573bc75-0023-1000-0080-0005cd3c17d4 Location: http://192.168.4.20:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Heos Office Link UID: uuid:71c0ce70-1678-1b74-0080-0005cd481e06 Location: http://192.168.4.91:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 RR2160_192.168.4.58 UID: uuid:6CBAc1b3-ed59-1900-4530-0022D9106CBA Location: http://192.168.4.58:49494/description.xml
Device #6: ID 0x0 Heos Office Link UID: uuid:9ff3b956-d82a-128c-0080-0005cd481e06 Location: http://192.168.4.91:60006/upnp/desc/aios_device/aios_device.xml
Device #7: ID 0x0 Heos Office Link UID: uuid:2cfc56b7-a44f-185f-0080-0005cd481e06 Location: http://192.168.4.91:60006/upnp/desc/aios_device/aios_device.xml
Device #8: ID 0x0 Heos Office Link UID: uuid:c61878f7-0e75-8f4f-ab84-fdf7da8f4535 Location: http://192.168.4.91:60006/upnp/desc/aios_device/aios_device.xml
Device #9: ID 0x0 Heos Office Link UID: uuid:cb6d121e-72c6-6928-6afc-0e20d8f59988 Location: http://192.168.4.91:60006/upnp/desc/aios_device/aios_device.xml
Device #10: ID 0x0 HEOS-Bedroom-R UID: uuid:1573bdca-0023-1000-0080-0005cd3c17d4 Location: http://192.168.4.20:60006/upnp/desc/aios_device/aios_device.xml
Device #11: ID 0x0 HEOS-Bedroom-R UID: uuid:1573be11-0023-1000-0080-0005cd3c17d4 Location: http://192.168.4.20:60006/upnp/desc/aios_device/aios_device.xml
Device #12: ID 0x0 HEOS-Bedroom-R UID: uuid:b94a6458-9527-11ea-92ed-0005cd3c17d4 Location: http://192.168.4.20:60006/upnp/desc/aios_device/aios_device.xml
Device #13: ID 0x0 HEOS-Bedroom-R UID: uuid:53cb7ec4-ee5b-11e3-a546-63f349f40588 Location: http://192.168.4.20:60006/upnp/desc/aios_device/aios_device.xml
Device #14: ID 0x0 Heos Kitchen UID: uuid:ae41ada4-8665-1697-0080-0005cd522e22 Location: http://192.168.4.21:60006/upnp/desc/aios_device/aios_device.xml
Device #15: ID 0x0 Heos Kitchen UID: uuid:1cf5312f-0cb8-1d4f-0080-0005cd522e22 Location: http://192.168.4.21:60006/upnp/desc/aios_device/aios_device.xml
Device #16: ID 0x0 Heos Kitchen UID: uuid:c5ba69e0-df26-5ca7-cb9e-3191c216a61f Location: http://192.168.4.21:60006/upnp/desc/aios_device/aios_device.xml
Device #17: ID 0x0 Heos Kitchen UID: uuid:ff5de15c-16c2-fd18-c1e6-fb9567289626 Location: http://192.168.4.21:60006/upnp/desc/aios_device/aios_device.xml
Device #18: ID 0x0 Heos Bathroom UID: uuid:028f82e7-f104-1a43-0080-0005cd526996 Location: http://192.168.4.22:60006/upnp/desc/aios_device/aios_device.xml
Device #19: ID 0x0 Heos Bathroom UID: uuid:756e7759-7b86-1b31-0080-0005cd526996 Location: http://192.168.4.22:60006/upnp/desc/aios_device/aios_device.xml
Device #20: ID 0x0 Heos Bathroom UID: uuid:bc4ce02d-f70d-7ee2-d32a-7679abc8ffe9 Location: http://192.168.4.22:60006/upnp/desc/aios_device/aios_device.xml
Device #21: ID 0x0 Heos Bathroom UID: uuid:17b19b04-75bc-3b10-bb04-a203f403d217 Location: http://192.168.4.22:60006/upnp/desc/aios_device/aios_device.xml
Device #22: ID 0x0 Heos-Bedroom-L UID: uuid:4e303324-c5d6-1270-0080-0005cd3bd767 Location: http://192.168.4.23:60006/upnp/desc/aios_device/aios_device.xml
Device #23: ID 0x0 Heos-Bedroom-L UID: uuid:c8fd619e-c671-1877-0080-0005cd3bd767 Location: http://192.168.4.23:60006/upnp/desc/aios_device/aios_device.xml
Device #24: ID 0x0 Heos-Bedroom-L UID: uuid:53d7b770-ee5b-11e3-b0b7-f5dfbb10e8b8 Location: http://192.168.4.23:60006/upnp/desc/aios_device/aios_device.xml
Device #25: ID 0x0 Heos-Bedroom-L UID: uuid:549ba6c6-ee5b-11e3-959a-e77123b17920 Location: http://192.168.4.23:60006/upnp/desc/aios_device/aios_device.xml
Device #0: ID 0x52 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:90 UID: AppleHDAEngineOutput:1B,0,1,2:0
An excellent diagnosgic question. I picked the device called “Heos Kitchen,” which is a first-generation Denon Heos One speaker. When I play an album from Audirvana on an iMac to the RR2160, it plays the first two songs and then stops. When I play to the Heos speaker, it plays normally.
Also: In Adirvana’s output device list (image uploaded), the RR2160 is listed once, but the Heos devices are listed once at the top, and then an additional four times further down.
Also, I have to quit and relaunch Audirvana to be able to change the output device. Stopping playback doesn’t do it.
Also I have a couple of Audirvana crash logs. Do you want those?
I’m using an eero mesh network. MacOS Catalina.
Thanks for your help and continued involvement!
If you can send me that last one at support@audirvana.com this would be great.
As for Heos device we will need to contact Denon about it as another user sent me a file that indicates something weird in the UPnP implementation.
Crash log sent. Is the bottom line that I can’t use Audirvana directly to my receiver because of DLNA problems, and I will have to add some other hardware solution such as a transport?
