Hi, I’ve just bought a new Cambridge Audio CXA61 and connected it my my Macbook pro through USB 2.0 but cannot get any audio out. The CXA is showing as selected device in device manager and in Audirvana but when I play a track it keeps switching to Internal Speaker as output but no sound at all.
Thanks for any help!
Debug info:
macOS 10.14.6 with 4096MB RAM
Registered to Warren Green
Per track: OFF
Replay Gain: by album
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/Dhanyavada/Music/Adyashanti Audio
AUTO: /Users/Dhanyavada/Music/MQA:Hi Res Samples
iTunes/Music library synchronization: last synchronized on Thu May 21 04:01:08 2020
Library database path: /Users/Dhanyavada/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
CA CXA61 2.0
Model UID:CA CXA61 2.0:22E8:CA02
UID:AppleUSBAudioEngine:CA:CA CXA61 2.0:14100000:1
ID 0x39 CA CXA61 2.0 Manufacturer:CA
Model UID:CA CXA61 2.0:22E8:CA02 UID:AppleUSBAudioEngine:CA:CA CXA61 2.0:14100000:1
9 available sample rates up to 705600Hz
Stream ID 0x3a 2 channels starting at 1
27 virtual formats:
36 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x39 CA CXA61 2.0 Manufacturer: CA Model UID: CA CXA61 2.0:22E8:CA02 UID: AppleUSBAudioEngine:CA:CA CXA61 2.0:14100000:1
