Hi
After playing radio for several hours, player got into a loop - filmed it, I can share if required, must be several megs, I don’t think it should be uploaded here.
Pls let me know.
BR,
Emmanuel
Dump
Audirvana Studio 1.13.1 (11301)
Windows 11 (22000) with 16GB physical RAM
Connected account of : Emmanuel VIGOT
Manual: (OFFLINE) C:\Dropbox\Dropbox\MyMusic
Library database path: C:\Users\Emmanuel\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:cb00:d9:1b00:417c:c020:9a48:86fe on port 61117
Max. memory for audio buffers: 4140MB
Local Audio Engine: ASIO ASIO 2 driver version 791
Marantz XM ASIO Device
Model UID:Marantz XM ASIO Device
Device: 2ch 32bits Integer, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
Manufacturer:
Model Name: Marantz XM ASIO Device
Model UID: Marantz XM ASIO Device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Local devices found : 3
Device #0: JRiver Media Center 28 Manufacturer: Model UID: JRiver Media Center 28 UID: JRiver Media Center 28 Model Name: JRiver Media Center 28
Device #1: Marantz XM ASIO Device Manufacturer: Model UID: Marantz XM ASIO Device UID: Marantz XM ASIO Device Model Name: Marantz XM ASIO Device
Device #2: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO Model Name: Realtek ASIO
UPnP devices found : 6
Device #0Marantz AV7706 UID: uuid:9f3ae4a1-36b0-1114-0080-000678547cee Location: http://192.168.36.13:60006/upnp/desc/aios_device/aios_device.xml
Device #1Décodeur TV UHD UID: uuid:00ababad-7947-1048-8a00-a89a93f07ba4 Location: http://192.168.36.3:42300/description.xml
Device #2Marantz AV7706 UID: uuid:565aa029-4864-130e-0080-000678547cee Location: http://192.168.36.13:60006/upnp/desc/aios_device/aios_device.xml
Device #3Marantz AV7706 UID: uuid:f403fb8f-2c69-19f6-0080-000678547cee Location: http://192.168.36.13:60006/upnp/desc/aios_device/aios_device.xml
Device #4Marantz AV7706 UID: uuid:d703d474-c170-513b-c275-7ed687d66a0f Location: http://192.168.36.13:60006/upnp/desc/aios_device/aios_device.xml
Device #5Marantz AV7706 UID: uuid:8ec2f217-9425-ae89-c55c-adcdad856277 Location: http://192.168.36.13:60006/upnp/desc/aios_device/aios_device.xml
