I recently tried connecting my laptop directly to my DAC (Yggy with Unison USB) and am having an issue with volume control: it goes from zero sound to way too loud when moving the Audirvana slider no more than 6mm. Audirvana is set to use software volume control. I thought this might be an issue with Windows mixer but I can set the system volume to 1 or 100 and it makes no difference with the Audirvana volume control. Any help appreciated. Oh I also tried setting Audirvana to use keyboard volume controls but end up with the same issue: one or two clicks from zero and its way too loud.
Hello @boleary,
I’ve sent this as sugested, paste in reply, but I don’t believe you ever received it so I’m pasting the file here. Thanks.
Brian
Thanks for the quick reply. Normally I use an Allo Digione but recently upgraded my usb input in my DAC and wanted to give it a listen. Here is the Debug Info:
Audirvana 3.5.38
Per track: OFF
SoX custom frequencies
Bandwidth at 0dB = 79.9927
Filter max length = 100
Phase = 100
Replay Gain: by track
SW volume control: ON
Sync list: 3 folders
AUTO: F:\Music II
AUTO: F:\Music\Music\Music
AUTO: C:\Users\Brian\Music
Library database path: C:\Users\Brian\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 15038MB
Local Audio Engine:WASAPI
Speakers (Schiit Yggdrasil Unison USB )
Model UID:Speakers (Schiit Yggdrasil Unison USB )
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{811e322a-70c0-4b41-bd3b-cdbca5957f18}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 192kHz
Speakers (Schiit Yggdrasil Unison USB ) Manufacturer:
Model UID:Speakers (Schiit Yggdrasil Unison USB ) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{811e322a-70c0-4b41-bd3b-cdbca5957f18}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Speaker/HP (Realtek High Definition Audio) Manufacturer: Model UID: Speaker/HP (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{57558efd-f651-46ea-9203-97fcd2f99e7e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Schiit Yggdrasil Unison USB ) Manufacturer: Model UID: Speakers (Schiit Yggdrasil Unison USB ) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{811e322a-70c0-4b41-bd3b-cdbca5957f18}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 2
Device #0TSR-5790 D0BDC2 UID: uuid:9ab0c000-f668-11de-9976-00a0ded0bdc2 Location: http://10.0.0.143:49154/MediaRenderer/desc.xml
Device #1Volumio UID: uuid:04255cb4-11f0-58db-0053-b827eb7be862 Location: http://10.0.0.102:49152/description.xml
Hello @boleary, when you don’t have volume control enable, you can’t change your audio output audio in Audirvana?
