Shiit Modius and tubed amp headphones. With Tidal or native windows playback - plenty of DB. With Audirvana I can only get about 1/2 of playing level.
Anything I missed? Ive scoured the app and this forum.
Hello @mjlandy,
Of course. Much appreciated Damiien3. I should add this low volume is most noticeable when I stream from TIDAL. Local library files are rather OK. The native TIDAL desktop app is almost 50% higher in DB output to the amp. I can get by but regardless of leveling mode some tracks are just too soft.
Im running BeyerDynamics open cans.
Audirvana 3.5.43
Replay Gain: by track
SW volume control: ON
AUTO: D:\iTunes Export
Library database path: D:\audirvana\AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Login failed
Max. memory for audio buffers: 49300MB
Local Audio Engine:WASAPI
Speakers (Schiit Unison Modius )
Model UID:Speakers (Schiit Unison Modius )
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{62f28ac0-ae67-45e9-9e5a-760c0b9abe57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Speakers (Schiit Unison Modius ) Manufacturer:
Model UID:Speakers (Schiit Unison Modius ) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{62f28ac0-ae67-45e9-9e5a-760c0b9abe57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Local devices found : 4
Device #0: Monitor (2- NVIDIA High Definition Audio) Manufacturer: Model UID: Monitor (2- NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{69130f02-9436-42f7-9cf6-497c934e82f6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: X35 HDMI (2- NVIDIA High Definition Audio) Manufacturer: Model UID: X35 HDMI (2- NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{324f8a45-6e1d-48b0-838f-6bc3e2b29fa5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Realtek Digital Output (Realtek® Audio) Manufacturer: Model UID: Realtek Digital Output (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b2b9ac5e-0dc9-4d14-b118-86145fa4c4f9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Speakers (Schiit Unison Modius ) Manufacturer: Model UID: Speakers (Schiit Unison Modius ) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{62f28ac0-ae67-45e9-9e5a-760c0b9abe57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 2
Device #0RuneAudio UID: uuid:e3ca3693-f4eb-af24-8f5b-dca632b0b072 Location: http://192.168.1.174:49152/uuid-e3ca3693-f4eb-af24-8f5b-dca632b0b072/description.xml
Device #1[LG] webos office UID: uuid:8ffeac54-dc8e-523b-647a-73b91da9311b Location: http://192.168.1.58:1906/
I should add. The sound stage and range is much improved compared to a stock setup.
Try to turn off software volume contol and also Replay Gain.
BINGO!
Thank you so much
