No audio devices detected
Hi,
have a weird issue on my M1 Mac and Audirvana 3.5 where non of the audio devices are detected by the program, including Built-in System Output. It looks like the problem occurs after couple of sleep/wakeup cycles. All works fine after system restart.
Ps. How can I attach debug info, got the message about exceeded characters amount.
EDIT: Screenshot attached
Hello @piko,
Can you send us a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>General>Debug Info
Translated Report (Full Report Below)
Process: Audirvana [56397]
Path: /Applications/Audirvana.app/Contents/MacOS/Audirvana
Identifier: com.audirvana.Audirvana
Version: 3.5.50 (3580)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-02-03 09:36:35.7035 +0100
OS Version: macOS 12.2 (21D49)
Report Version: 12
Anonymous UUID: CEF3EDB9-AE62-F1C0-D067-64E0D683313B
Sleep/Wake UUID: EB72F188-D10B-47DF-90BE-AC9189CBE00C
Time Awake Since Boot: 430000 seconds
Time Since Wake: 126204 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0xfffffffffffffed7
Exception Codes: 0x0000000000000001, 0xfffffffffffffed7
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [56397]
VM Region Info: 0xfffffffffffffed7 is not in any region. Bytes after previous region: 18446743592673214168
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
commpage (reserved) 1000000000-7000000000 [384.0G] —/— SM=NUL …(unallocated)
UNUSED SPACE AT END
Application Specific Information:
Performing @selector(showDebugInfo:) from sender NSMenuItem 0x12af3fcf0
Kernel Triage:
VM - pmap_enter failed with resource shortage
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 Audirvana 0x10316b74c 0x102fe0000 + 1619788
1 Audirvana 0x10316b72c 0x102fe0000 + 1619756
2 Audirvana 0x103163868 0x102fe0000 + 1587304
3 Audirvana 0x103345b54 0x102fe0000 + 3562324
4 Audirvana 0x1034c7234 0x102fe0000 + 5141044
5 Audirvana 0x103472fc0 0x102fe0000 + 4796352
6 Audirvana 0x10320f4d4 0x102fe0000 + 2290900
7 AppKit 0x1ba341400 -[NSApplication(NSResponder) sendAction:to:from:] + 456
8 AppKit 0x1ba436f84 -[NSMenuItem _corePerformAction] + 444
9 AppKit 0x1ba436c78 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 100
10 AppKit 0x1ba47f40c -[NSMenu performActionForItemAtIndex:] + 196
11 AppKit 0x1ba47f330 -[NSMenu _internalPerformActionForItemAtIndex:] + 100
12 AppKit 0x1ba47f13c -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 116
13 AppKit 0x1ba41ab70 NSSLMMenuEventHandler + 728
14 HIToolbox 0x1c0157418 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1116
15 HIToolbox 0x1c0156884 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 356
16 HIToolbox 0x1c016c9c4 SendEventToEventTarget + 40
17 HIToolbox 0x1c01ccca0 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 420
18 HIToolbox 0x1c01f19f8 SendMenuCommandWithContextAndModifiers + 56
19 HIToolbox 0x1c01f1988 SendMenuItemSelectedEvent + 352
20 HIToolbox 0x1c01f17b4 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 100
21 HIToolbox 0x1c01f216c MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 564
22 HIToolbox 0x1c01f1e88 _HandleMenuSelection2 + 416
23 AppKit 0x1ba2da3fc _NSHandleCarbonMenuEvent + 288
24 AppKit 0x1ba2da1e8 _DPSEventHandledByCarbon + 68
25 AppKit 0x1ba13c0a4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3380
26 AppKit 0x1ba12d9b4 -[NSApplication run] + 596
27 AppKit 0x1ba0ff088 NSApplicationMain + 1064
28 dyld 0x103c650f4 start + 520
Thread 1:
0 libsystem_pthread.dylib 0x1b7518010 start_wqthread + 0
Thread 2:: Dispatch queue: com.apple.root.default-qos
0 libsystem_kernel.dylib 0x1b74e50c0 __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x1b751d808 _pthread_cond_wait + 1228
2 libc++.1.dylib 0x1b746bddc std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 28
3 Audirvana 0x10316555c 0x102fe0000 + 1594716
4 Audirvana 0x1030dbc28 0x102fe0000 + 1031208
5 Audirvana 0x103165478 0x102fe0000 + 1594488
6 libdispatch.dylib 0x1b735ebac _dispatch_client_callout + 20
7 libdispatch.dylib 0x1b7361cd4 _dispatch_queue_override_invoke + 792
8 libdispatch.dylib 0x1b737031c _dispatch_root_queue_drain + 396
9 libdispatch.dylib 0x1b7370b58 _dispatch_worker_thread2 + 164
10 libsystem_pthread.dylib 0x1b75192c8 _pthread_wqthread + 228
11 libsystem_pthread.dylib 0x1b7518018 start_wqthread + 8
Thread 3:
Thread 4:
Thread 5:
3 Audirvana 0x1036ee05c 0x102fe0000 + 7397468
4 libsystem_pthread.dylib 0x1b751d240 _pthread_start + 148
5 libsystem_pthread.dylib 0x1b7518024 thread_start + 8
Thread 6:
2 Audirvana 0x103075f4c 0x102fe0000 + 614220
3 Audirvana 0x103075bd0 0x102fe0000 + 613328
Thread 7:
2 Audirvana 0x103075af0 0x102fe0000 + 613104
3 libsystem_pthread.dylib 0x1b751d240 _pthread_start + 148
4 libsystem_pthread.dylib 0x1b7518024 thread_start + 8
Thread 8:
0 libsystem_kernel.dylib 0x1b74ebd38 __select + 8
1 Audirvana 0x10307b2d4 0x102fe0000 + 635604
2 Audirvana 0x103075bd0 0x102fe0000 + 613328
Thread 9:
Thread 10:
Thread 11:
Thread 12:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x1b74e1954 mach_msg_trap + 8
1 libsystem_kernel.dylib 0x1b74e1d00 mach_msg + 76
2 CoreFoundation 0x1b75e8ed8 __CFRunLoopServiceMachPort + 372
3 CoreFoundation 0x1b75e7390 __CFRunLoopRun + 1212
4 CoreFoundation 0x1b75e6734 CFRunLoopRunSpecific + 600
5 CFNetwork 0x1bc3fbe30 0x1bc18d000 + 2551344
6 Foundation 0x1b84b42e8 NSThread__start + 808
7 libsystem_pthread.dylib 0x1b751d240 _pthread_start + 148
8 libsystem_pthread.dylib 0x1b7518024 thread_start + 8
Thread 13:: AMCP Logging Spool
0 libsystem_kernel.dylib 0x1b74e1990 semaphore_wait_trap + 8
1 caulk 0x1bfef08ac caulk::mach::semaphore::wait_or_error() + 28
2 caulk 0x1bfed365c caulk::concurrent::details::worker_thread::run() + 56
3 caulk 0x1bfed327c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void) + 96
Thread 14:: com.apple.NSEventThread
5 AppKit 0x1ba2a9fb0 _NSEventThread + 196
6 libsystem_pthread.dylib 0x1b751d240 _pthread_start + 148
7 libsystem_pthread.dylib 0x1b7518024 thread_start + 8
Thread 15:: com.apple.CFSocket.private
1 CoreFoundation 0x1b7613334 __CFSocketManager + 648
2 libsystem_pthread.dylib 0x1b751d240 _pthread_start + 148
3 libsystem_pthread.dylib 0x1b7518024 thread_start + 8
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x000000016ce1e220 x1: 0x000000016ce1e220 x2: 0x0000000000000000 x3: 0x000000012c0d8fc5
x4: 0x000000016ce1e4b8 x5: 0x0000000000000020 x6: 0x000000000000003a x7: 0x0000000000000001
x8: 0x0000000000000010 x9: 0x0000000000000001 x10: 0x0000000000000002 x11: 0x0000000000000000
x12: 0x0000000000000015 x13: 0x0000000000000005 x14: 0x0000000008000000 x15: 0x00000002106254c0
x16: 0x0000000210ba21a0 x17: 0x1be800016ce1e220 x18: 0x000000013078b940 x19: 0x000000016ce1e220
x20: 0x000000016ce1e550 x21: 0x000000016ce1e550 x22: 0xfffffffffffffe58 x23: 0xffffffffffffffff
x24: 0x0000000000000000 x25: 0x0000000103975cf5 x26: 0x0000000103ae9c40 x27: 0x000000016ce1e4b8
x28: 0x0000000103ae9c40 fp: 0x000000016ce1e3e0 lr: 0x697e00010316b72c
sp: 0x000000016ce1e1d0 pc: 0x000000010316b74c cpsr: 0x20001000
far: 0xfffffffffffffed7 esr: 0x92000004 (Data Abort) byte read Translation fault
Binary Images:
0x102fe0000 - 0x103ac7fff com.audirvana.Audirvana (3.5.50) /Applications/Audirvana.app/Contents/MacOS/Audirvana
0x1ba0fb000 - 0x1bafb1fff com.apple.AppKit (6.9) <1b65b629-6d3b-3fcd-ad43-e5683a9f94b7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x1c014c000 - 0x1c047bfff com.apple.HIToolbox (2.1.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x103c60000 - 0x103cbffff dyld () /usr/lib/dyld
0x1b7516000 - 0x1b7522fff libsystem_pthread.dylib (
) /usr/lib/system/libsystem_pthread.dylib
0x1b74e0000 - 0x1b7515fff libsystem_kernel.dylib () <384945e6-dd71-37e5-9a3d-84fff14a1e60> /usr/lib/system/libsystem_kernel.dylib
0x1b7462000 - 0x1b74c5fff libc++.1.dylib (
) <0eb3a986-b1bc-3f18-b7cc-51e2e5e00dc3> /usr/lib/libc++.1.dylib
0x1b735b000 - 0x1b73a1fff libdispatch.dylib () <93e1dcfc-ef56-3113-8e7c-1ba85266a93b> /usr/lib/system/libdispatch.dylib
0x1b7564000 - 0x1b7aa7fff com.apple.CoreFoundation (6.9) <16fadf8b-a3af-3e0c-b5fb-ce9a9cdc8747> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1bc18d000 - 0x1bc645fff com.apple.CFNetwork (1329) /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x1b8458000 - 0x1b8845fff com.apple.Foundation (6.9) <90321a38-43a5-3767-9a9c-2c631338b9bc> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x1bfed1000 - 0x1bfef8fff com.apple.audio.caulk (1.0) /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x0 - 0xffffffffffffffff ??? (
) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
M Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=411.3M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=411.3M(100%)
                            VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 512K 4
Activity Tracing 256K 1
CG backing stores 6720K 8
CG image 1952K 15
ColorSync 592K 26
CoreAnimation 70.6M 297
CoreGraphics 48K 3
CoreUI image data 1312K 10
Dispatch continuations 64.0M 1
Foundation 16K 1
Image IO 16K 1
Kernel Alloc Once 32K 1
MALLOC 131.4M 62
MALLOC guard page 288K 15
MALLOC_MEDIUM (reserved) 112.0M 1 reserved VM address space (unallocated)
SQLite page cache 448K 7
STACK GUARD 56.4M 28
Stack 22.3M 28
VM_ALLOCATE 1.0G 25
__AUTH 2530K 308
__AUTH_CONST 19.3M 491
__DATA 15.5M 483
__DATA_CONST 17.3M 500
__DATA_DIRTY 1746K 209
__FONT_DATA 4K 1
__LINKEDIT 576.8M 10
__OBJC_CONST 3414K 272
__OBJC_RO 82.1M 1
__OBJC_RW 3104K 1
__TEXT 476.4M 520
__UNICODE 588K 1
dyld private memory 1024K 1
libnetwork 1664K 24
mapped file 362.5M 34
shared memory 880K 14
TOTAL 3.0G 3404
TOTAL, minus reserved VM space 2.9G 3404
Full Report
{“app_name”:“Audirvana”,“timestamp”:“2022-02-03 09:36:36.00 +0100”,“app_version”:“3.5.50”,“slice_uuid”:“d775f583-3610-39f2-800f-8d7f51b02634”,“build_version”:“3580”,“platform”:1,“bundleID”:“com.audirvana.Audirvana”,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.2 (21D49)”,“incident_id”:“CFACD544-015B-4C28-A7D0-E7C020867AF1”,“name”:“Audirvana”}
“uptime” : 430000,
“procLaunch” : “2022-02-03 09:36:23.3123 +0100”,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro17,1”,
“procStartAbsTime” : 10367790526014,
“coalitionID” : 21598,
“osVersion” : {
“train” : “macOS 12.2”,
“build” : “21D49”,
“releaseType” : “User”
“captureTime” : “2022-02-03 09:36:35.7035 +0100”,
“incident” : “CFACD544-015B-4C28-A7D0-E7C020867AF1”,
“bug_type” : “309”,
“pid” : 56397,
“procExitAbsTime” : 10368087765467,
“translated” : false,
“cpuType” : “ARM-64”,
“procName” : “Audirvana”,
“procPath” : “/Applications/Audirvana.app/Contents/MacOS/Audirvana”,
“bundleInfo” : {“CFBundleShortVersionString”:“3.5.50”,“CFBundleVersion”:“3580”,“CFBundleIdentifier”:“com.audirvana.Audirvana”},
“storeInfo” : {“deviceIdentifierForVendor”:“179B630A-2D06-5CAD-A994-FF84829E5687”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.audirvana.Audirvana”,
“crashReporterKey” : “CEF3EDB9-AE62-F1C0-D067-64E0D683313B”,
“wakeTime” : 126204,
“sleepWakeUUID” : “EB72F188-D10B-47DF-90BE-AC9189CBE00C”,
“sip” : “enabled”,
“vmRegionInfo” : “0xfffffffffffffed7 is not in any region. Bytes after previous region: 18446743592673214168 \n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n commpage (reserved) 1000000000-7000000000 [384.0G] —/— SM=NUL …(unallocated)\n—> \n UNUSED SPACE AT END”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0xfffffffffffffed7”,“rawCodes”:[1,-297],“type”:“EXC_BAD_ACCESS”,“signal”:“SIGSEGV”,“subtype”:“KERN_INVALID_ADDRESS at 0xfffffffffffffed7”},
“termination” : {“flags”:0,“code”:11,“namespace”:“SIGNAL”,“indicator”:“Segmentation fault: 11”,“byProc”:“exc handler”,“byPid”:56397},
“ktriageinfo” : “VM - pmap_enter failed with resource shortage\n”,
“vmregioninfo” : “0xfffffffffffffed7 is not in any region. Bytes after previous region: 18446743592673214168 \n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n commpage (reserved) 1000000000-7000000000 [384.0G] —/— SM=NUL …(unallocated)\n—> \n UNUSED SPACE AT END”,
“asi” : {“AppKit”:[“Performing @selector(showDebugInfo:) from sender NSMenuItem 0x12af3fcf0”]},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:3770851,“threadState”:{“x”:[{“value”:6121710112},{“value”:6121710112},{“value”:0},{“value”:5034053573},{“value”:6121710776},{“value”:32},{“value”:58},{“value”:1},{“value”:16},{“value”:1},{“value”:2},{“value”:0},{“value”:21},{“value”:5},{“value”:134217728},{“value”:8864814272,“symbolLocation”:0,“symbol”:“OBJC_CLASS_$___NSCFString”},{“value”:8870568352,“symbolLocation”:16,“symbol”:“vtable for std::__1::basic_streambuf<char, std::__1::char_traits >”},{“value”:2010857239742636576},{“value”:5108185408},{“value”:6121710112},{“value”:6121710928},{“value”:6121710928},{“value”:18446744073709551192},{“value”:18446744073709551615},{“value”:0},{“value”:4355218677},{“value”:4356742208},{“value”:6121710776},{“value”:4356742208}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:7601513225394763564},“cpsr”:{“value”:536875008},“fp”:{“value”:6121710560},“sp”:{“value”:6121710032},“esr”:{“value”:2449473540,“description”:“(Data Abort) byte read Translation fault”},“pc”:{“value”:4346787660,“matchesCrashFrame”:1},“far”:{“value”:18446744073709551319}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:1619788,“imageIndex”:0},{“imageOffset”:1619756,“imageIndex”:0},{“imageOffset”:1587304,“imageIndex”:0},{“imageOffset”:3562324,“imageIndex”:0},{“imageOffset”:5141044,“imageIndex”:0},{“imageOffset”:4796352,“imageIndex”:0},{“imageOffset”:2290900,“imageIndex”:0},{“imageOffset”:2384896,“symbol”:“-[NSApplication(NSResponder) sendAction:to:from:]”,“symbolLocation”:456,“imageIndex”:1},{“imageOffset”:3391364,“symbol”:“-[NSMenuItem _corePerformAction]”,“symbolLocation”:444,“imageIndex”:1},{“imageOffset”:3390584,“symbol”:“-[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:]”,“symbolLocation”:100,“imageIndex”:1},{“imageOffset”:3687436,“symbol”:“-[NSMenu performActionForItemAtIndex:]”,“symbolLocation”:196,“imageIndex”:1},{“imageOffset”:3687216,“symbol”:“-[NSMenu _internalPerformActionForItemAtIndex:]”,“symbolLocation”:100,“imageIndex”:1},{“imageOffset”:3686716,“symbol”:“-[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:]”,“symbolLocation”:116,“imageIndex”:1},{“imageOffset”:3275632,“symbol”:“NSSLMMenuEventHandler”,“symbolLocation”:728,“imageIndex”:1},{“imageOffset”:46104,“symbol”:“DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*)”,“symbolLocation”:1116,“imageIndex”:2},{“imageOffset”:43140,“symbol”:“SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*)”,“symbolLocation”:356,“imageIndex”:2},{“imageOffset”:133572,“symbol”:“SendEventToEventTarget”,“symbolLocation”:40,“imageIndex”:2},{“imageOffset”:527520,“symbol”:“SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**)”,“symbolLocation”:420,“imageIndex”:2},{“imageOffset”:678392,“symbol”:“SendMenuCommandWithContextAndModifiers”,“symbolLocation”:56,“imageIndex”:2},{“imageOffset”:678280,“symbol”:“SendMenuItemSelectedEvent”,“symbolLocation”:352,“imageIndex”:2},{“imageOffset”:677812,“symbol”:“FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*)”,“symbolLocation”:100,“imageIndex”:2},{“imageOffset”:680300,“symbol”:“MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*)”,“symbolLocation”:564,“imageIndex”:2},{“imageOffset”:679560,“symbol”:“_HandleMenuSelection2”,“symbolLocation”:416,“imageIndex”:2},{“imageOffset”:1963004,“symbol”:“_NSHandleCarbonMenuEvent”,“symbolLocation”:288,“imageIndex”:1},{“imageOffset”:1962472,“symbol”:“_DPSEventHandledByCarbon”,“symbolLocation”:68,“imageIndex”:1},{“imageOffset”:266404,“symbol”:“-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]”,“symbolLocation”:3380,“imageIndex”:1},{“imageOffset”:207284,“symbol”:“-[NSApplication run]”,“symbolLocation”:596,“imageIndex”:1},{“imageOffset”:16520,“symbol”:“NSApplicationMain”,“symbolLocation”:1064,“imageIndex”:1},{“imageOffset”:20724,“symbol”:“start”,“symbolLocation”:520,“imageIndex”:3}]},{“id”:3770859,“frames”:[{“imageOffset”:8208,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:4}]},{“id”:3770860,“queue”:“com.apple.root.default-qos”,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:40412,“symbol”:“std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&)”,“symbolLocation”:28,“imageIndex”:6},{“imageOffset”:1594716,“imageIndex”:0},{“imageOffset”:1031208,“imageIndex”:0},{“imageOffset”:1594488,“imageIndex”:0},{“imageOffset”:15276,“symbol”:“_dispatch_client_callout”,“symbolLocation”:20,“imageIndex”:7},{“imageOffset”:27860,“symbol”:“_dispatch_queue_override_invoke”,“symbolLocation”:792,“imageIndex”:7},{“imageOffset”:86812,“symbol”:“_dispatch_root_queue_drain”,“symbolLocation”:396,“imageIndex”:7},{“imageOffset”:88920,“symbol”:“_dispatch_worker_thread2”,“symbolLocation”:164,“imageIndex”:7},{“imageOffset”:13000,“symbol”:“_pthread_wqthread”,“symbolLocation”:228,“imageIndex”:4},{“imageOffset”:8216,“symbol”:“start_wqthread”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770944,“frames”:[{“imageOffset”:8208,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:4}]},{“id”:3770945,“frames”:[{“imageOffset”:8208,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:4}]},{“id”:3770953,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:40412,“symbol”:“std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&)”,“symbolLocation”:28,“imageIndex”:6},{“imageOffset”:7397468,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770954,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:614220,“imageIndex”:0},{“imageOffset”:613328,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770955,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770958,“frames”:[{“imageOffset”:48440,“symbol”:“__select”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:635604,“imageIndex”:0},{“imageOffset”:613328,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770961,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770966,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770967,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770973,“name”:“com.apple.NSURLConnectionLoader”,“frames”:[{“imageOffset”:6484,“symbol”:“mach_msg_trap”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:7424,“symbol”:“mach_msg”,“symbolLocation”:76,“imageIndex”:5},{“imageOffset”:544472,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:372,“imageIndex”:8},{“imageOffset”:537488,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1212,“imageIndex”:8},{“imageOffset”:534324,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:600,“imageIndex”:8},{“imageOffset”:2551344,“imageIndex”:9},{“imageOffset”:377576,“symbol”:“NSThread__start”,“symbolLocation”:808,“imageIndex”:10},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3770974,“name”:“AMCP Logging Spool”,“frames”:[{“imageOffset”:6544,“symbol”:“semaphore_wait_trap”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:129196,“symbol”:“caulk::mach::semaphore::wait_or_error()”,“symbolLocation”:28,“imageIndex”:11},{“imageOffset”:9820,“symbol”:“caulk::concurrent::details::worker_thread::run()”,“symbolLocation”:56,“imageIndex”:11},{“imageOffset”:8828,“symbol”:“void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void)”,“symbolLocation”:96,“imageIndex”:11},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771002,“name”:“com.apple.NSEventThread”,“frames”:[{“imageOffset”:6484,“symbol”:“mach_msg_trap”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:7424,“symbol”:“mach_msg”,“symbolLocation”:76,“imageIndex”:5},{“imageOffset”:544472,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:372,“imageIndex”:8},{“imageOffset”:537488,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1212,“imageIndex”:8},{“imageOffset”:534324,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:600,“imageIndex”:8},{“imageOffset”:1765296,“symbol”:“_NSEventThread”,“symbolLocation”:196,“imageIndex”:1},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771003,“name”:“com.apple.CFSocket.private”,“frames”:[{“imageOffset”:48440,“symbol”:“__select”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:717620,“symbol”:“__CFSocketManager”,“symbolLocation”:648,“imageIndex”:8},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771022,“frames”:[{“imageOffset”:8208,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:4}]},{“id”:3771026,“frames”:[{“imageOffset”:8208,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:4}]},{“id”:3771027,“frames”:[{“imageOffset”:8208,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:4}]},{“id”:3771072,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771073,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771074,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771075,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771076,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771077,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771078,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771079,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:3771080,“frames”:[{“imageOffset”:20672,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:5},{“imageOffset”:30728,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1228,“imageIndex”:4},{“imageOffset”:613104,“imageIndex”:0},{“imageOffset”:29248,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:4},{“imageOffset”:8228,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]}],
“usedImages” : [
“source” : “P”,
“arch” : “arm64”,
“base” : 4345167872,
“CFBundleShortVersionString” : “3.5.50”,
“CFBundleIdentifier” : “com.audirvana.Audirvana”,
“size” : 11436032,
“uuid” : “d775f583-3610-39f2-800f-8d7f51b02634”,
“path” : “/Applications/Audirvana.app/Contents/MacOS/Audirvana”,
“name” : “Audirvana”,
“CFBundleVersion” : “3580”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7416557568,
“CFBundleShortVersionString” : “6.9”,
“CFBundleIdentifier” : “com.apple.AppKit”,
“size” : 15429632,
“uuid” : “1b65b629-6d3b-3fcd-ad43-e5683a9f94b7”,
“path” : “/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit”,
“name” : “AppKit”,
“CFBundleVersion” : “2113.30.116”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7517552640,
“CFBundleShortVersionString” : “2.1.1”,
“CFBundleIdentifier” : “com.apple.HIToolbox”,
“size” : 3342336,
“uuid” : “b5a3fe9a-833b-3697-ac9c-1e9e8eb11bac”,
“path” : “/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox”,
“name” : “HIToolbox”
“source” : “P”,
“arch” : “arm64e”,
“base” : 4358275072,
“size” : 393216,
“uuid” : “d21a73ea-79cd-36eb-8ac9-2c5cf5181a27”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7370530816,
“size” : 53248,
“uuid” : “f7b2eccf-e6f1-3109-ae81-9028c0b8332a”,
“path” : “/usr/lib/system/libsystem_pthread.dylib”,
“name” : “libsystem_pthread.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7370309632,
“size” : 221184,
“uuid” : “384945e6-dd71-37e5-9a3d-84fff14a1e60”,
“path” : “/usr/lib/system/libsystem_kernel.dylib”,
“name” : “libsystem_kernel.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7369793536,
“size” : 409600,
“uuid” : “0eb3a986-b1bc-3f18-b7cc-51e2e5e00dc3”,
“path” : “/usr/lib/libc++.1.dylib”,
“name” : “libc++.1.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7368716288,
“size” : 290816,
“uuid” : “93e1dcfc-ef56-3113-8e7c-1ba85266a93b”,
“path” : “/usr/lib/system/libdispatch.dylib”,
“name” : “libdispatch.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7370850304,
“CFBundleIdentifier” : “com.apple.CoreFoundation”,
“size” : 5521408,
“uuid” : “16fadf8b-a3af-3e0c-b5fb-ce9a9cdc8747”,
“path” : “/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation”,
“name” : “CoreFoundation”,
“CFBundleVersion” : “1856.105”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7450710016,
“CFBundleShortVersionString” : “1329”,
“CFBundleIdentifier” : “com.apple.CFNetwork”,
“size” : 4952064,
“uuid” : “a48c10c0-0aef-3d9f-b050-06420ab96929”,
“path” : “/System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork”,
“name” : “CFNetwork”,
“CFBundleVersion” : “1329”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7386529792,
“CFBundleIdentifier” : “com.apple.Foundation”,
“size” : 4120576,
“uuid” : “90321a38-43a5-3767-9a9c-2c631338b9bc”,
“path” : “/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation”,
“name” : “Foundation”,
“source” : “P”,
“arch” : “arm64e”,
“base” : 7514951680,
“CFBundleShortVersionString” : “1.0”,
“CFBundleIdentifier” : “com.apple.audio.caulk”,
“size” : 163840,
“uuid” : “f8f1663b-806a-3544-9a8b-2a595d06dfdd”,
“path” : “/System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk”,
“name” : “caulk”
“size” : 0,
“source” : “A”,
“base” : 0,
“uuid” : “00000000-0000-0000-0000-000000000000”
“sharedCache” : {
“base” : 7367360512,
“size” : 3091218432,
“uuid” : “b90241b2-e425-3982-b3f6-26c4567cbb49”
“vmSummary” : “ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=411.3M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=411.3M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 512K 4 \nActivity Tracing 256K 1 \nCG backing stores 6720K 8 \nCG image 1952K 15 \nColorSync 592K 26 \nCoreAnimation 70.6M 297 \nCoreGraphics 48K 3 \nCoreUI image data 1312K 10 \nDispatch continuations 64.0M 1 \nFoundation 16K 1 \nImage IO 16K 1 \nKernel Alloc Once 32K 1 \nMALLOC 131.4M 62 \nMALLOC guard page 288K 15 \nMALLOC_MEDIUM (reserved) 112.0M 1 reserved VM address space (unallocated)\nSQLite page cache 448K 7 \nSTACK GUARD 56.4M 28 \nStack 22.3M 28 \nVM_ALLOCATE 1.0G 25 \n__AUTH 2530K 308 \n__AUTH_CONST 19.3M 491 \n__DATA 15.5M 483 \n__DATA_CONST 17.3M 500 \n__DATA_DIRTY 1746K 209 \n__FONT_DATA 4K 1 \n__LINKEDIT 576.8M 10 \n__OBJC_CONST 3414K 272 \n__OBJC_RO 82.1M 1 \n__OBJC_RW 3104K 1 \n__TEXT 476.4M 520 \n__UNICODE 588K 1 \ndyld private memory 1024K 1 \nlibnetwork 1664K 24 \nmapped file 362.5M 34 \nshared memory 880K 14 \n=========== ======= ======= \nTOTAL 3.0G 3404 \nTOTAL, minus reserved VM space 2.9G 3404 \n”,
“legacyInfo” : {
“threadTriggered” : {
“queue” : “com.apple.main-thread”
“trialInfo” : {
“rollouts” : [
“rolloutId” : “607844aa04477260f58a8077”,
“factorPackIds” : {
“SIRI_MORPHUN_ASSETS” : “6103050cbfe6dc472e1c982a”
“deploymentId” : 240000066
“rolloutId” : “60da5e84ab0ca017dace9abf”,
“factorPackIds” : {
  "deploymentId" : 240000008
  "rolloutId" : "5fc94383418129005b4e9ae0",
  "factorPackIds" : {
  "deploymentId" : 240000225
  "rolloutId" : "601d9415f79519000ccd4b69",
  "factorPackIds" : {
    "SIRI_TEXT_TO_SPEECH" : "61f0405329647d394933a4c4"
  "deploymentId" : 240000378
  "rolloutId" : "602ad4dac86151000cf27e46",
  "factorPackIds" : {
    "SIRI_DICTATION_ASSETS" : "61f03e2e29647d394933a4be"
  "deploymentId" : 240000298
  "rolloutId" : "5ffde50ce2aacd000d47a95f",
  "factorPackIds" : {
  "deploymentId" : 240000102
“experiments” : [
Model: MacBookPro17,1, BootROM 7429.81.3, proc 8:4:4 processors, 16 GB, SMC
Graphics: Apple M1, Apple M1, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Display: LG Ultra HD, 6016 x 3384, MirrorOff, Online
Memory Module: LPDDR4
AirPort: Wi-Fi, wl0: Oct 26 2021 16:10:41 version 18.20.310.15.7.8.120 FWID 01-5d6c3867
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: USB3.0 Hub
USB Device: USB3.0 Card Reader
USB Device: 4-Port USB 3.0 Hub
USB Device: USB 10/100/1000 LAN
USB Device: USB2.0 Hub
USB Device: 4-Port USB 2.0 Hub
USB Device: Live! Cam Sync 1080p
USB Device: Pre Box S2 Digital
USB Device: USB 2.0 BILLBOARD
USB Device: hub_device
USB Device: TUSB3410 EECode Ser
USB Device: Texas Instruments USB Billboard Device
Thunderbolt Bus: MacBook Pro, Apple Inc.
Can you please try to install Audirvāna again using this link?
https://audirvana.com/legacy-mac
Ok, I did, what’s next? (Still no devices shown).
Can you open Audio midi setup app from the utilities app of MacOS? Do you see any device in it?
No devices in the MIDI Setup App
If you try to play a Youtube video, do you get any sound from your Mac Speakers?
Yes, all works fine, actually currently listening to Music app on my DAC
This is strange, I will talk about this with Damien and come back to you as soon as possible.
Thank you, also to add, I have other MacBook, Intel based running Big Sur and never had issues like that and been using Audirvana for few years. My hunch is that the issue is connected to M1 / Monterey.
Can you try to open your Mac is Safe mode to check if you see an output in the MIDI app?
Restarted (not even in safe mode) and all devices are back to midi setup and Audirvana. As mentioned before the issue seems to be present after few sleep/wake cycles.
