Catalina 10.15.7
Audirvana 3.5.42
Just updated to Audirvana 3.5.42. No audio from USB devices, even though selected in Audirvana. The two devices in question are a Mackie DL16S mixer, and a Redgum RGDAC8. Playout to AirPods Pro OK.
Catalina 10.15.7
Audirvana 3.5.42
Hello @digitus,
macOS 10.15.7 with 8192MB RAM
Registered to Benjamin Lian
AUTO: /Users/blian/Music/iTunes
Library database path: /Users/blian/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HD USB Audio
Model UID:HD USB Audio:262A:9227
UID:AppleUSBAudioEngine:XENRAN Audio:HD USB Audio:14400000:2
Active Sample Rate: 48kHz
ID 0x3a HD USB Audio Manufacturer:XENRAN Audio
Model UID:HD USB Audio:262A:9227 UID:AppleUSBAudioEngine:XENRAN Audio:HD USB Audio:14400000:2
32000
Stream ID 0x3b 2 channels starting at 1
36 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
54 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Local devices found : 6
Device #0: ID 0x69 DELL U2711 Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{AC10-A056-3036544C}
Device #1: ID 0x6d DL16S Manufacturer: LOUD Audio, LLC Model UID: DL16S:0A73:0021 UID: AppleUSBAudioEngine:LOUD Audio, LLC:DL16S:14200000:1,2
Device #2: ID 0x3a HD USB Audio Manufacturer: XENRAN Audio Model UID: HD USB Audio:262A:9227 UID: AppleUSBAudioEngine:XENRAN Audio:HD USB Audio:14400000:2
Device #3: ID 0x58 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #4: ID 0x30 EpocCam Microphone Manufacturer: Kinoni Oy Model UID: VirtualMicInputOutput:01 UID: VirtualMicInputOutput:01
Device #5: ID 0x5e iShowU Audio Capture Manufacturer: shinywhitebox ltd. Model UID: com_shinywhitebox_iShowU_Audio_Capture:iShowU Audio Capture UID: iShowUAudioEngine:0
UPnP devices found : 1
Device #0: ID 0x0 Mu-so-PP UID: uuid:5F9EC1B3-ED59-79BB-4530-3010B3FDCC82 Location: http://192.168.68.107:8080/description.xml
Does it happen when you play local, Tidal content or both?
Can you try to disable Integer mode in the audio output settings?
Happens when attempting to play local and Tidal content.
Audirvana DOES play tunes when integer mode is turned off!
