when i try to enable DSD upsampling i got no audio playback and when I change it to anything else it works
I’m Using HP Z420 V2 workstation connected to Pioneer Preamp and power amp
ho to solve it as I’m a newcomer to upsampling
Can you paste the debug info here?
How can I get it?
can you show me
Audirvana 3.5.44
SoX to DSD64 with filter type B 7th order
Phase = 85
AUTO: D:
Library database path: C:\Users\AhMeD\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4088MB
Local Audio Engine:WASAPI
Speakers (Realtek High Definition Audio)
Model UID:Speakers (Realtek High Definition Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{45cb988c-eef6-42ed-abb9-be34ebb349c4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Speakers (Realtek High Definition Audio) Manufacturer:
Model UID:Speakers (Realtek High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{45cb988c-eef6-42ed-abb9-be34ebb349c4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{45cb988c-eef6-42ed-abb9-be34ebb349c4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
I don’t see your device selected, can you select it in Audirvana and send your debug info again?
Hi, I have the same problem, so I’ll paste my debug info:
macOS 10.12.6 with 12288MB RAM
Registrado a XXX
SoX to DSD128 with filter type A 4th order
Phase = 100
SW volume control: ON
Sync list: 4 folders
AUTO: /Users/Ismael/Documents/iso2dsd_OSX_v6/Russian National Orchestra, conducted by Mikhail Pletnev - Tchaikovsky - Symphony No. 6 in B minor Op. 74 Pathétiqu
AUTO: /Users/Ismael/Downloads/1974. Rory Gallagher - Irish Tour '74… (2014, 7CD+DVD, 40th Anniversary Deluxe Box Set, Sony, EU, UK, 88875004882)
Manual: (OFFLINE) /Volumes/TOSHIBA EXT/The Doors/The Doors - Perception [DVD-A 24bit 96Khz]/1971 - L.A. Woman
Manual: (OFFLINE) /Volumes/TOSHIBA EXT/Tom Waits - Rain Dogs [SMH SACD]
Library database path: /Users/Ismael/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 9818MB
Exclusive access: Disabled
BursonAudio USB Audio 2.0
Model UID:BursonAudio USB Audio 2.0:152A:86ED
UID:AppleUSBAudioEngine:XMOS:BursonAudio USB Audio 2.0:fa132000:1
ID 0x8d BursonAudio USB Audio 2.0 Manufacturer:XMOS
Model UID:BursonAudio USB Audio 2.0:152A:86ED UID:AppleUSBAudioEngine:XMOS:BursonAudio USB Audio 2.0:fa132000:1
Stream ID 0x8e 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 5
Device #0: ID 0x39 Salida integrada Manufacturer: Apple Inc. Model UID: AppleHDA:9 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0xa2 Creative BT-W3 Manufacturer: Creative Technology Ltd Model UID: Creative BT-W3:041E:3270 UID: AppleUSBAudioEngine:Creative Technology Ltd:Creative BT-W3:0086A026003C0002:1,2
Device #2: ID 0x8d BursonAudio USB Audio 2.0 Manufacturer: XMOS Model UID: BursonAudio USB Audio 2.0:152A:86ED UID: AppleUSBAudioEngine:XMOS:BursonAudio USB Audio 2.0:fa132000:1
Device #3: ID 0x2b BlackHole 2ch Manufacturer: Existential Audio Inc. Model UID: BlackHole2ch_ModelUID UID: BlackHole2ch_UID
Device #4: ID 0xb9 SoundID Reference Manufacturer: Sonarworks Model UID: SoundIDReference_ModelUID UID: SoundIDReference_DeviceUID
In case this helps anyone with the same issue, I changed the settings to Exclusive mode and it worked again.
