I bought the latest origin version a few days ago and the DAC exclusive loc access is not working. I can’t play any of my files,
Mac OS Monteray 12.6.5
Memory 8 gb
Processor 3 ghz 6 core intel
When I try to set up System Optimizer I receive a pop up error message
SymOptimizer error
… couldn’t commuinicate with helper application
Havcew chewcked the COmm Foeum and members refer to emptying Audirvana files from PrivilegedHelperTools but I have none - does this mean to have to reinstall Audirvana?
If it’s the case then you need to remove them, restart your computer and open Audirvāna Origin. If SysOptimizer is enabled, you should have a popup appearing asking you to install SysOptimizer, if it’s not the case, let me know.
Thanks for getting back so promptly
I have neither
/Library/PrivilegedHelperTools/com.audirvana.SysOptimizerTool
/Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
Steps 2
entered first command got terminal message
Load failed: 2: No such file or directory
entered second command got terminal message
There was an error executing SysOptimizer. Not all optimizations may be done.
Error = Couldn’t communicate with a helper application.
Critically the lock icon on the bottom right of interface is greyed out and has never been ‘lit’ properly in the entire time I’ve tried using this since purchase
Same as before- other infp
After reboot the lock icon appeared properly lit for. the first time but then dimmed
Under the Exclusive audio accessa mode disabled there’s the Bufferized section with five columns beneath that
On the far left it reads Loading then Buffer 3.3GB Nomral POlarity
beside that column is another titled Processing then another column Upsampling
These are all normally lit - the last two are dimmed - Volume Levelling and Volume Control
I have one ext HD with my 188,000 tracks in one folder
Same problem - removed the old PrivHelp andf LaunDem A origin files and replaced - rebooted PC
A started and unusually rescanned my music folder then I got opo up message “Y system has run out of app memory” then I got the by now VERY familiar pop up
“Sus Op Error - COuldnt communicate with helper app”
Now my pc is frozen with these two messages
This is insane .How can an app be so awful from the very beginning?
Try to go in the settings
in system optimizer gear wheel just up there, try to UNcheck time machine preference if it is on, restart mac, audirvana, click a song and see…
