i purchased the Audirvana Remote app for my iPhone yesterday & cannot get it to connect to my macOS Catalina. This is my OS data:
Audirvana Mac Version 3.5.30 (3560)
macOS 10.15.3 with 16384MB RAM
I have removed & reinstalled the Remote app w/ the same problem. I also verified the OS & iPhone are on the same wifi network, & verified the Firewall settings.
I fixed this myself. I connected my iPhone to my macOS & the computer name came up. I selected it & the ID number showed up on my mac & disappeared quickly. I got frustrated & disconnected my iPhone. My mac name stayed on my iPhone so I selected it again, then the ID showed up & stayed, so I entered it on my iPhone & it worked.
That’s different from router to router. You can start troubleshooting by connecting the Mac to the ethernet and changing the WiFi your device running Audirvana remote is.
If you manage to get it to work, ask somebody with knowledge how to manage your router to help you.
I have been on Audirvana for quite a while but I still get blocked by the system calling me a new user and saying I can only post 3 messages to a thread because I’m too new. So, how old do I have to be before I get full citizen status on Audirvana?
try to trash your iphone app…
hard shut down your iphone…
now it is close.
Go the iMac, check your wifi connection there… regular or 5g on same network… Open Iphone… check your wifi connection there to be the same as iMac… download again audirvana Remote from Macstore… open it… it has to see your Mac… enter the number to connect to it… voilà
sometimes on downstair room i lost the 5g connection on iphone and it now on regular wifi… i removed that wifi connection, only to allow the same from imac and iphone…
