damien3…how come my player only play 10 sec. of ANYTHING i select
Hello @bayrat,
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content, all you have to do is paste it in response to this mail.
songs play half through then stop…audvarna freeze up
Audirvana Studio 3.5.51 (2051)
Windows 10 (19043) with 6GB physical RAM
VST3 plugin #0: C:\Program Files\Common Files\VST3\SonEQFree.vst3
ClassID: F2AEE70D00DE4F4E536F6E69536F4551
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Sync list: 0 folders
Library database path: C:\Users\tscal\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1490MB
Local Audio Engine:WASAPI
Model UID:
UID:
Active Sample Rate: 48kHz
Speakers (3- AUDIOLAB USB Audio 2.0) Manufacturer:
Model UID:Speakers (3- AUDIOLAB USB Audio 2.0) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{c88bffb6-7cd6-4fa4-9835-0cd3155d6c59}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Speakers (3- AUDIOLAB USB Audio 2.0) Manufacturer: Model UID: Speakers (3- AUDIOLAB USB Audio 2.0) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c88bffb6-7cd6-4fa4-9835-0cd3155d6c59}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (High Definition Audio Device) Manufacturer: Model UID: Speakers (High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{cbd54f20-5963-46e7-9098-ef8b0072955a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
why song play half through then stop and audivarna freeze up
You can stop the realtime with your plugin… only 6gb of ram… if still stop, remove that plugin and see…
Detect if mqa, you said not mqa, so put that option at no detection…
ok
