Hi. Loaded latest Audirvana updates but problem remains. Audirvana does not recognize the Playback Designs MPD-3, even though it shows/been selected with the audio output. Only change is that Audirvana is now not defaulting to the internal speakers, just that there is no sound. Grateful any suggestions that would help get this fixed.
Mac or PC ?
Was playing before?
if on Mac, open Utilities folder and lauch Audio Midi Setup… can you see DAC there?
iMac running Sierra. Continuing problem, not affecting other DACs. Previously reverted to internal speakers, now just no sound. Checked Audio Midi, & MPD-3 appears there. Opening Audirvana seems to click MPD-3 off, rather than establishing handshake.
Hello @spesalium, Can you send me a copy of the “Debug Info” while you select your MPD-3? You can get it in Audirvana Settings>General>Debug Info
Hi. Appreciate the reply. Here’s the debug info. Thanks.
Audirvana Mac Version 3.5.40 (3570)
macOS 10.13.6 with 4096MB RAM
Registered to John Di Gangi
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Fri Jan 17 15:29:36 2020
Library database path: /Users/johndigangi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Max. memory for audio buffers: 1664MB
MPD-3
Model UID:MPD-3:23BA:0003
UID:AppleUSBAudioEngine:Playback Designs:MPD-3:fa140000:1
Active Sample Rate: 96kHz
ID 0x43 MPD-3 Manufacturer:Playback Designs
Model UID:MPD-3:23BA:0003 UID:AppleUSBAudioEngine:Playback Designs:MPD-3:fa140000:1
Stream ID 0x44 2 channels starting at 1
16 virtual formats:
16 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Device #0: ID 0x2f Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:24 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x43 MPD-3 Manufacturer: Playback Designs Model UID: MPD-3:23BA:0003 UID: AppleUSBAudioEngine:Playback Designs:MPD-3:fa140000:1
, or
Try to enable exclusive access and integer mode.
Appreciated the advice. Switched exclusive access and integer mode off & back on. Worked first time but not after I exited Audirvana, & tried it second time. Problem remains establishing reliable connection between Audirvana & MPD-3.
Looks like the magic combination is exclusive access on, integer mode off.
Power off both the device and the Mac. Start the Mac, power on the device and start Audirvana to make the settings changes.
