Have no sound when connecting to Audio research dac from Mac mini .
Can only play songs through optical head phone socket on Mac mini.The Mac keeps switching to internal speakers even though set to external dac
Hope you may be able to help
Tim
macOS 10.13.6 with 16384MB RAM
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat Apr 24 12:14:21 2021
Library database path: /Users/timwarke/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 15360MB
AUDIO RESEARCH CORP DAC
Model UID:com_audioresearch_dac_Device:DAC
UID:com_audioresearch_dac_UsbpalAudioEngine:0
Active Sample Rate: 192kHz
ID 0x27 AUDIO RESEARCH CORP DAC Manufacturer:AUDIO RESEARCH CORP
Model UID:com_audioresearch_dac_Device:DAC UID:com_audioresearch_dac_UsbpalAudioEngine:0
Simple stereo device: No
2 output streams:
Number of active channels: 2, in 2 stream(s)
Channel #1 :Stream 1 channel 0
Stream ID 0x28 1 channels starting at 1
6 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
6 physical formats
1 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 192kHz
1 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 176.4kHz
1 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 96kHz
1 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 88.2kHz
1 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 48kHz
1 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 44.1kHz
Stream ID 0x29 1 channels starting at 2
6 virtual formats:
6 physical formats
Device #0: ID 0x3b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x27 AUDIO RESEARCH CORP DAC Manufacturer: AUDIO RESEARCH CORP Model UID: com_audioresearch_dac_Device:DAC UID: com_audioresearch_dac_UsbpalAudioEngine:0
UPnP devices found : 1
Device #0: ID 0x0 Kitchen UID: uuid:5f9ec1b3-ed59-1900-4530-ec66d10311bf Location:
