Here it is :
Audirvana Mac Version 3.5.35 (3565)
macOS 10.13.6 with 8192MB RAM
Version d’essai utilisant une licence de démo
Per track: OFF
Max allowed volume: 0
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/Extreme SSD/AIFF
Manual: /Users/philippebossi/.Trash/Paul Chambers Quintet
Library database path: /Users/philippebossi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
SMSL M300
Model UID:SMSL M300:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL M300:1a120000:1
ID 0x4a SMSL M300 Manufacturer:SMSL
Model UID:SMSL M300:152A:85DD UID:AppleUSBAudioEngine:SMSL:SMSL M300:1a120000:1
Stream ID 0x4b 2 channels starting at 1
20 virtual formats:
20 physical formats
Device #0: ID 0x2f Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x4a SMSL M300 Manufacturer: SMSL Model UID: SMSL M300:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL M300:1a120000:1
