Can you try to create a copy of the file and remove the embedded cover art? You can use XLD on a Mac, check for suitable application if you’re on a Windows PC.
Downloaded XLD but not knowing the program, wasn’t sure what it could do other than converting files. did convert DSD to ALAC and the file played but only at 88.2 kHz. tried converting a DSD file back to DSD and it did play but again, at only 88.2 kHz.
Try to remove the cover art and the metadata.
Removed the cover art and metadata but that didn’t work either.
At this point it looks like Marantz issue, but just to exclude completely, you can try with some other UPnP streaming software.
Do you know of any others to try?
The obvious one to use is JRiver. Just start a trial and test.
Hello @Kmastro, do you still got the issue with JRiver? If it’s the case then you should contact marantz since you seems to have an issue with your DAC.
Hi, I am new to audirvana and I am having trouble getting it to work the right way. My setup is as follow: Marantz AV 7703 with heos built in. Audirvana running from a Windows 10 machine powered by Intel core i7 with 24 gbs memory. The problem is that the AVR wouldn’t play any file above 96/24 although the avr is perfectly capable of playing 192/24 and including DSD 256 natively. In addition to that, the fast forward and rewind functions are greyed out.
I am using audirvana version 3.54.
Please help
Hello @kingdarius01, Can you send me a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
Audirvana 3.5.4
Sync list: 2 folders
AUTO: H:
AUTO: C:\Users\kingd\Desktop\Saxolove
Library database path: C:\Users\kingd\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Marantz AV7703 Model UID:Marantz Marantz AV7703 UID:uuid:aa6b6dc7-1d5f-1d9d-0080-0005cd765700
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.1.174:60006/upnp/desc/aios_device/aios_device.xml
Marantz AV7703 Manufacturer:Marantz
Volume control: No
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://192.168.1.43:49152/audirvana/audio_0_4.wav
CurrentURIMetadata: dc:titleBe My Baby</dc:title>http://192.168.1.43:49152/audirvana/audio_0_4.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorAaron Neville</dc:creator>upnp:genreR&B</upnp:genre>upnp:artistAaron Neville</upnp:artist>upnp:albumMy True Story</upnp:album>upnp:albumArtURIhttp://192.168.1.43:49152/audirvana/artwork_0_5.jpg</upnp:albumArtURI>upnp:originalTrackNumber6</upnp:originalTrackNumber>
nextURI: http://192.168.1.43:49152/audirvana/audio_1_5.wav
nextURIMetadata: dc:titleLittle Bitty Pretty One</dc:title>http://192.168.1.43:49152/audirvana/audio_1_5.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorAaron Neville</dc:creator>upnp:genreR&B</upnp:genre>upnp:artistAaron Neville</upnp:artist>upnp:albumMy True Story</upnp:album>upnp:albumArtURIhttp://192.168.1.43:49152/audirvana/artwork_1_6.jpg</upnp:albumArtURI>upnp:originalTrackNumber7</upnp:originalTrackNumber>
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 GetCurrentState CurrentState out LastChange GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID X_SetShuffle InstanceID in A_ARG_TYPE_InstanceID Shuffle in X_Shuffle AVTransportURI string AVTransportURIMetaData string A_ARG_TYPE_CurrentState_AVTransport string A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_ObjectID string A_ARG_TYPE_SeekMode string TRACK_NR TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string AbsoluteCounterPosition ui4 AbsoluteTimePosition string CurrentMediaCategory string CurrentMediaDuration string CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL CurrentRecordQualityMode string CurrentTrack ui4 0 0 65535 1 CurrentTrackDuration string CurrentTrackMetaData string CurrentTrackURI string CurrentTransportActions string LastChange string NextAVTransportURI string NextAVTransportURIMetaData string NumberOfTracks ui4 0 0 65535 PlayMode ui4 0 PlaybackStorageMedium string PossiblePlaybackStorageMedia string PossibleRecordQualityModes string PossibleRecordStorageMedia string RecordMediumWriteStatus string RecordStorageMedium string RelativeCounterPosition i4 RelativeTimePosition string TransportPlaySpeed string 1 1 12 -12 TransportState string STOPPED STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING TransportStatus string OK OK ERROR_OCCURRED X_Shuffle boolean 0Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Marantz AV7703 Marantz http://www.marantz.com Marantz AV7703 Aios 4.025 uuid:aa6b6dc7-1d5f-1d9d-0080-0005cd765700 00000002 1256 8080 urn:schemas-upnp-org:device:MediaRenderer:1 Marantz AV7703 Marantz http://www.marantz.com Marantz AV7703 Aios 4.025 uuid:40561da1-5c96-1b4c-0080-0005cd765700 QPlay:1 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-denon-com:device:AiosServices:1 AiosServices Marantz http://www.marantz.com Marantz AV7703 Aios 4.025 uuid:3889e14a-ed63-1216-0080-0005cd765700 urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-upnp-org:device:MediaServer:1 Marantz AV7703 Marantz http://www.marantz.com Shares User defined folders and files to other Universal Plug and Play media devices. Marantz AV7703 Aios 4.025 0000001 uuid:06c4085e-ded2-7333-4f6b-bf7cb8dd82e0 True True True True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManager urn:schemas-denon-com:device:ACT-Denon:1 ACT-Marantz AV7703 Marantz http://www.marantz.com Marantz AV7703 Aios 4.025 uuid:5ef74618-0e7b-050c-1819-455f41580d2f AIOS:0001 147202 Thu 2019-09-12 02:43:50 1.520.200 00:05:CD:76:56:FE en_NA 4 Aios 4.025 1 Production 00:05:CD:76:57:00 urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/eventUPnP devices found : 6
Device #0[TV] Samsung 8 Series (65) UID: uuid:d7fee4c7-38e9-4ba0-81ef-a54dcb77e3ee Location: http://192.168.1.221:9197/dmr
Device #1Marantz AV7703 UID: uuid:aa6b6dc7-1d5f-1d9d-0080-0005cd765700 Location: http://192.168.1.174:60006/upnp/desc/aios_device/aios_device.xml
Device #2Marantz AV7703 UID: uuid:40561da1-5c96-1b4c-0080-0005cd765700 Location: http://192.168.1.174:60006/upnp/desc/aios_device/aios_device.xml
Device #3Marantz AV7703 UID: uuid:3889e14a-ed63-1216-0080-0005cd765700 Location: http://192.168.1.174:60006/upnp/desc/aios_device/aios_device.xml
Device #4Marantz AV7703 UID: uuid:06c4085e-ded2-7333-4f6b-bf7cb8dd82e0 Location: http://192.168.1.174:60006/upnp/desc/aios_device/aios_device.xml
Device #5Marantz AV7703 UID: uuid:5ef74618-0e7b-050c-1819-455f41580d2f Location: http://192.168.1.174:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 6302MB
Local Audio Engine:WASAPI
Device #0: SAMSUNG (NVIDIA High Definition Audio) Manufacturer: Model UID: SAMSUNG (NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d4bed459-bcb6-4f62-8b03-efab40199330}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Realtek Digital Output (Realtek High Definition Audio) Manufacturer: Model UID: Realtek Digital Output (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{6eddcf27-e3b9-4399-aeca-228c67ceb570}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
I assume that you can listen to DSD music using the HEOS app from Marantz?
Yes i am able to stream DSD from the Heos app and the same goes for bubble upn and jriver too. I udated to audirvana version 3.5.5 and i am still unable to stream DSD or any file above 24/96 in addition to that i cannot fast forward or rewind.
Was there ever a solution to Marantz avr not playing audio file 24/192? It seems that audirvana droppped support for Marantz AVRs and that’s sad.
It was established that the Marantz avr wasn’t the problem because the Marantz avr is perfectly capable of playing 24/192 and DSD natively. For instance, I can stream any type file and including DSD 5.6 from minimserver, asset UPnP, and bubble upn without any issue. Well, I sent my debug file to audirvana a few times already and I am still waiting for an answer.
Can you set the native DSD read method to “DSD over PCM 1.0” in the device section of the audio settings page?
I tried all the settings and none of them worked. DSD over PCM doesn’t work for me, still no sound when playing file 24/192
