I am not seeing a volume slider or control in the remote app in IOS for Ipad or Iphone. Is this normal?
Same in my case. Both using iPad and iPhone. I have Audirvana Windows 10 version.
The volume control appears initially, but then disappears. Both iPhone and iPad are affected in my case, too. Developers?
I have No volume control in my Audirvana remote
Hello @Music, To get this volume slider you need to enable software volume control in your audio output settings in Audirvana.
Thanks, Damien. Got Audirvana today, and loaded the apps on my iPhone and iPad. Saw the volume slider briefly, and then it disappeared. Simple solution.
