Thanks, here’s the debug info:
Replay Gain: by track
AUTO: /Volumes/Audirvana Database 2TB/
iTunes/Music library synchronization: last synchronized on Sat Jul 11 14:38:37 2020
Library database path: /Users/michaelmorse/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 15360MB
AudioQuest DragonFly Cobalt v1.0
Model UID:AudioQuest DragonFly Cobalt v1.0:21B4:0085
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100103921:1
Active Sample Rate: 96kHz
ID 0x31 AudioQuest DragonFly Cobalt v1.0 Manufacturer:AudioQuest
Model UID:AudioQuest DragonFly Cobalt v1.0:21B4:0085 UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100103921:1
Audio buffer frame size : 27 to 4096 frames
Stream ID 0x32 2 channels starting at 1
8 virtual formats:
8 physical formats
Local devices found : 4
Device #0: ID 0x70 DELL U2417H Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{AC10-40E7-3538314C}
Device #1: ID 0x31 AudioQuest DragonFly Cobalt v1.0 Manufacturer: AudioQuest Model UID: AudioQuest DragonFly Cobalt v1.0:21B4:0085 UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100103921:1
Device #2: ID 0x35 CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:200000:1
Device #3: ID 0x57 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 2
Device #0: ID 0x0 [TV] Samsung 6 Series (55) UID: uuid:323e3ee0-8139-4f36-8e7b-4fd49a30aa4a Location: http://192.168.1.92:9197/dmr
Device #1: ID 0x0 LS50 Wireless II-1509ae UID: uuid:3c4ed890-9474-42a1-ae00-15895477808a Location: http://192.168.1.128:46153/3c4ed890-9474-42a1-ae00-15895477808a.xml
